Thread: camber
    Regular Member linley85's Avatar
    sinfin, derby
    Default camber
    what would the benefits be if i would lower my elite 35mm and adjust the camber
    cheers dan
    cambs
    the lower center of gravity helps on cornering and less roll
    sinfin, derby
    would there be any point with the camber adjustment or would it just be a waste of money
    cambs
    you really need it done but a lot of people dont bother.
    sinfin, derby
    cause i noticed on lmf you can buy the camber adjustment bolts for the front would they be the ideal thing
    cambs
    they are made to make it easyer to adjust the camber.but i dont think you need it as it just makes it easyer to adjust.
    for how much they are i would buy them anyway m8 allways better to have all the correct parts.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    i didnt have mine adjusted and its wore the inner side of my front tyres out so its worth getting checked once the suspension has settled.
    sinfin, derby
    i thought it would eb better to buy the proper kit cause im not that up on my knowledge of suspension
    cambs
    Quote Originally Posted by linley85 View Post
    yep get the camber bolts m8 allways nice to know you have new parts and the correct ones.
    cambs
    you might also need some bump stops aswell m8.
    not to sure but some-one will probely tell you if you need them.
  1. bad camber!!
    By wullie-t27 in forum Handling & Braking
    Last Post: 9th November 2012, 21:06
  2. rear camber
    By cliff75 in forum Suspension, Wheels & Brakes
    Last Post: 6th July 2012, 14:38
  3. Camber? Camber Kits??
    By RyanNI in forum Handling & Braking
    Last Post: 13th December 2010, 11:11
  4. camber kit
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2009, 09:23
  5. Camber
    By Daywalker in forum Handling & Braking
    Last Post: 22nd June 2008, 10:46
