Cant beleive the problems started by a glow plug!
As you all know my head has had some work done to it due to the snapping of plugs.
I had a full head change and starter and turbo.
Starter _ Because it burnt out due to non starting
Turbo _ Because i thought the old one had blown but it never
Head _ Wel the old one was F U B A R because i had a pice of old glow plug stuck in there and it bent valves and snapped a part under the cam?
thus running V v bad.
New parts fitted £600 pluss spent and it started and run sound.
Done 3.6 mile and it stopped dead on the drive.
Charged the battery 2 times due to non starting.
Thought thats it had enough its going on Flea Bay
On as a non starter but i had got a second opinion from another fitter.
Glad i did because when inspecting the engine i pulled the leak off pipes out my way to see why i had oil under them. It fell off with ease, went on to check the rest and there where 4 compleatly split 100% the way through. £1.00 on parts £20 on fitting and that was it pumped the fuel back in and it stated no problem and starts every time now.
Phew nearly sold the lot!
