Thread: Heater Control Panel Removal
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Default Heater Control Panel Removal
    Hi
    Does anyone know how to remove the heater control panel as I have bought a Brodit phone braket and it clips behind the back of the left hand side of the heater control panel. I have had a little fiddle and tried prizing the unit out but no joy.
    Regular Member shan's Avatar
    I pulled out the ashtray, then the letterbox thingy pulls out, then the heater control pulls out "hold it underneath"
    May 2007
    WINSFORD
    Quote Originally Posted by shan View Post
    So there is no screws to deal with then. I am a bit heavy handed at times so I didnt pull to hard earlier incase I got the dreaded CRACK
    Quote Originally Posted by ANDY W View Post
    Only if you get lucky.
    No mate none at all.
    May 2007
    WINSFORD
    Cool, thanks shan, I will have a go tomorrow and let you know how things go
    lincolnshire
    Heater control panel, is held in by sprung clips, if you take time and gradually prise out each side you should get it without removing radio, if radio is removed it makes the job easier.....
    Quote Originally Posted by vxrcourt3 View Post
    If you remove it from the bottom like i suggested it eliminates the risk of damaging the dash with the screwdriver
    You have not seen the size of mine and Andy fat finger's the can corse a lot of damage
  1. Removal of Heater Control Panel
    By Richard Bignell in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2010, 17:37
  2. Heater control panel
    By daviek in forum Parts for sale
    Last Post: 24th September 2007, 12:55
  3. Heater Control Panel
    By faz3270 in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2007, 15:33
  4. heater control panel
    By daviek in forum Bodywork & Interior
    Last Post: 13th October 2006, 21:09
vectra c heater control panel removal
how do you remove the centre control panel on a vauxhall vectra c 2007
vauxhall vectra c heater control panel
https:www.vectra-c.comforumshowthread.php62492-Heater-Control-Panel-Removal
2006 vectra c heating controls
how to remove vectra c heater control panel
how to.change heater control vauxhall signum
vectra c heater control knob removal
heating panel vectra c
remove vectra c climate control unit
vectra c heater control removal
hownto remove heater control panel vectra c
remove heater control vectra
how do you remove the heater control panel on a Vauxhall Vectra
how do you remove the climate control console on a Signum
how to remove heater control on a vauxhall vectra c
vectra c heater controls removal
how to remove heater control vectra c
remove corsa c heater controls
removing the heater controls Vauxhall Vectra
how to remove heater controls on a vectra
vauxhall insignia how to change heating control panel
vectra c heater panel removal
vectra c remove control panel
