Thread: How DO you bleed a diesel
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    Default How DO you bleed a diesel
    As above, luckily Ive never ran out of diesel have always woundered how to bleed a modern diesel I thought older diesels had a rubber bulb you had to squeeze or a plunger to keep pressing/
    Just curious really, also I dont intend on running out as it can **** your engine apperently
    Jul 2006
    Aren't they automatic bleeding? ie with the engine turning over?
    Full Member
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Should be in your manual:
    Diesel fuel system, bleeding
    Never let the tank run dry. If control
    indicator illuminates, refuel as soon as
    possible. Refuel immediately if it flashes.
    Restarting after running out of fuel is
    possible, but starting behaviour will be
    delayed. Turn on the ignition three times
    for 15 seconds each time. Then start the
    engine for a maximum of 40 seconds. If it
    does not start, repeat the process after
    waiting at least 5 seconds. If the engine still
    does not start, contact a workshop.
    deanos
    Guest
    I ran out of Diesel and it automatically bled itself, took about 3 turns of the key and it started.
    Belfast
    Keep cranking, it'll start just before the starter bursts into flames.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    2.0 and 2.2 dti models can be a pig to start,the 1.9s have an internal pump in the tank so self bleed
    Apr 2008
    Burton on Trent
    I left mine parked facing up my driveway when I went away on holiday, took me about 10 min of turning to gt it going again. Battery is very good
    1.9's self bleed, the older DTi's need a specific bleed kit and is a 4-spanner job according to Haynes...
    .. or , you just fill the fuel filter bowl with DERV and overfill it viathe screwhole on the top to expel all air, then turn the key.....
  1. Clutch Bleed
    By mat_splat in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2012, 19:36
  2. Bleed valve on a 2.0t
    By tomo41 in forum Petrol Engine related
    Last Post: 26th June 2011, 12:50
  3. how to bleed the clutch
    By vectra3.2dave in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2010, 14:26
  4. LCD bleed
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 18:49
  5. Any one recommend a bleed kit?
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2009, 00:33
how to bleed vectra diesel
How to bleed clutch z19dth
z19dth how to bleed
