Results 1 to 10 of 28
Thread: Timing chain snapped !
    Regular Member Ant SRi's Avatar
    Merseyside
    Default Timing chain snapped !
    Hi,
    Well what I thought was a fuel problem is not! Actually the timing chain has given up.
    I've not pulled it apart yet, but what are the chances that there is no more damage apart from the chain? Is this a 'clearance engine' does anyone know?
    It's a z22yh engine.
    Cheers,
    Mileage : 000
    Fingers crossed it is ok. I don,t know the answer for you, but I do hope for the best. PM gsi3.2 (Mark) he will be able to tell you.
    Sunny Dartmoor
    Gutted for you m8,hope it gets sorted quickly with minimal fuss......
    Belfast
    Quote Originally Posted by Ant SRi View Post
    You wish. Prepare to have a hefty bill heading your way.
    Regular Member Jim Bob's Avatar
    Widnes, Cheshire
    Bad news that.. Was told mine was close to snapping at only 26000 due to a faulty tensioner....
    Good luck
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    well if nothing happend... then you are lucky.. the valvs are gone.. at least some of them, if it snaped during engine on..
    But try and make VX pay as they know its a fault on there engine (they did on mine after 40000 miles..)
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    If it just did not start then the chances are its just new valves, but if it stopped while running then its a far far bigger job mate. Gutted for you mate.
    Merseyside
    Well the odd thing is that it does still turn over and runs (very low tick over and then stalls) which is why i thought it was the fuel system.
    But i've had a garage look at it and they say there is no compression on any pot.
    I'm gonna get it back at the weekend and pull it apart see what the score is.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    In that case it hasn't snapped, its jumped a few teeth and the timing is way out.... You might not have damaged anything, and all you might need is a new timing chain kit? Fingers crossed.
    EDIT You say your going to pull it apart? In that case you sound a competent spanner man and if so and it turns out just to have jumped and there are no bent valves then just over £100 to Autovaux for the kit and you could have it fixed.
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Try installing 2.0T tensioners when you do the repair!!Hope it's sorted soon mate.
  1. chain snapped need timing diagrams, please help.
    By daz-b in forum Engine & Drivetrain
    Last Post: 8th April 2012, 12:39
  2. 2.2 Elite Direct Timing Chain Snapped
    By pete the feet in forum Engine & Drivetrain
    Last Post: 27th March 2011, 14:26
  3. Timing chain 2.2 dti
    By tditony in forum Diesel Engine related
    Last Post: 17th March 2011, 03:31
  4. 2.2 Timing chain Snapped (2.2se)
    By Goonerman in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2010, 22:16
  5. 2.2 timing chain
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2008, 15:54
z22se balance shaft chain snapped
vauxhall z22yh engine be damaged if the timing chain snaps
Vectra c 2.2 direct balance chain snapped
z22se chain snapping
