Thread: emmissions light
    middlesbrough
    Default emmissions light
    had my stainless exhaust fitted for 5 days now and the emmissions light has just come on. i am having it reduced from 3" to 2.5" after the sports cat back to the y section on saturday will this make a difference. what should i do about this problem. starting to think i shouldent have bothered.
    Regular Member big O's Avatar
    Good old Sunny Scunny!!!!
    my exhaust is 2.5" straight through with duel 4" exits, and it's spot on. it did make a difference from standard.
    middlesbrough
    if i have the engine remaped again after the exhaust was fitted would that eliminate the problem with the emmissions light.
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    See what code is in the ecu mate!! my car had a fault with the egt sensor witch was damaged when the down pipe was fitted.But if it's a lamda sensor your car can over fuel and burnout the cat!! But i think this only happens when in limp mode.hth
    Jul 2006
    You need to know what the problem is before you can start trying to fix it.
  1. Emmissions light coming on when accelerating
    By watchman in forum Engine & Drivetrain
    Last Post: 16th September 2011, 14:57
  2. Emmissions Light
    By IWC in forum Engine & Drivetrain
    Last Post: 21st January 2011, 13:57
  3. Emmissions light on. Help needed asap
    By stokie-lee in forum Engine & Drivetrain
    Last Post: 29th July 2010, 12:00
  4. emmissions light on dashboard
    By pmitchell in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2010, 17:57
  5. 2.2 petrol LS engine cuting out and emmissions fault light on!
    By affirmation in forum Engine & Drivetrain
    Last Post: 2nd November 2009, 15:00
