Hi guys are there any fixes for creaking drivers seat and is it a waranty issue, 2008 sri xp2, also can the keyless entry be altered to one press for full opening ? Sorry if this is a repost.
Seat = warranty issue. Its normally a new seat neededInterior trim is covered for 1 year only, how old is the car, I'm assuming as you have said 2008 its not a year old yet.
Not sure on the opening.
I had the same problem on a 2007 sri (new to me with 4000 on the clock and 8 months old). Used to creek everytime I moved in the seat or went over a bump. I fiddled with the seat adjustments, basically moved the seat up and down, tilted and untilted it a few times. I put my problem down to having the seat on it's lowest setting (due to my height) and now keep it a single ratchet off minimum. Been fine since, touch wood(10 months). Hope you get it sorted
I recently took my Signum in because the seat was squaeking. I had my seat frame replaced under warranty, mine's an 06/06 but with full used NetQ warranty.
And yes, you can set up one touch opening - it's in the owner's manual and also (i think) in the How2 section on here.
