Results 1 to 10 of 30
Thread: vectra estate front suspension creak?
    Regular Member bigsteve's Avatar
    Apr 2008
    Nottingham
    Default vectra estate front suspension creak?
    Hi all, i have an annoying problem when i drive over speed bumps there is a dreadful creak, almost plasticky in sound, it only happens when the car is driven over the bumps with both front wheels, if you drive over with just either the left or right wheel over the bump it is silent...i have changed the anti roll bar links recently as they were knocking, but this has got me totally lost, has anyone had similar probs? cheers.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Mine has started to do the same thing, and I think its the anti-roll bar bushes - I'm on my third set though!
    Jul 2006
    First things first - has it got the spring seat mods? If you feel behind the front wheel, in the pan of the shock absorber, the bottom coil of the spring should have a rubber sleeve over it. If not, that's a cheap option...
    Either that or engine mounts have been known to squeak...
    Mileage : 000
    The radiator mounts are known to squeak too.
    Jul 2006
    that's what I meant...
    Newport
    Ive got the same problem as you bigsteve, aint got a clue where to start to eliminate. I thought it might be suspension as it only seems to happen when the suspension is compressed over any little bump.
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    I have this problem too, more of a problem after coming down over a speed bump, a real bad creaking crunching noise. Definitely not radiator mounts for me, they've been done. do know if I'm imagining it or not but may seem worse in the cold (could this help narrow the problem down any ) I shall watch this thread with great interest.
    Quote Originally Posted by JuzzyD View Post
    I'd say that as I have the spring seat mod and the rad mounts mod all done and its still doing it. Pretty sure its not the engine mounts. hth
    preston
    My car 54 plate does exactly the same over speed bumps only, otherwise ok. Its like a creak type noise not a knock. Sounds Mcphearson strut related. Not having a look now in this weather, will have to wait till summertime!
    Andover
    Just to add to the fray, I came to the forum in search of answer for this exact problem, a cracking noise, and quite a loud one at that, coming from the front suspension over speed bumps, its worse coming off the speed bump. It only happens over speed bumps so until a resolution is found I suggest we ban speed bumps. Im writing to my MP!
  1. Replies: 24
    Last Post: 23rd April 2018, 11:01
  2. Strange Creak from Front Suspension
    By eddie twadds in forum Suspension, Wheels & Brakes
    Last Post: 12th March 2012, 21:43
  3. Suspension creak... again...
    Last Post: 29th December 2008, 22:44
  4. A Creak But not Suspension
    By fattony in forum Vectra C / Signum Car Chat
    Last Post: 25th December 2008, 14:29
  5. rear suspension creak
    By chris.100 in forum Suspension, Wheels & Brakes
    Last Post: 22nd February 2008, 00:29
vectra c creaking front suspension
why does my vectra c sri estate creak
vectra c sri estate front creaking noise
vectra c top of suspension creaking
