Results 1 to 10 of 28
Thread: Temp Related Cruise Control
    Regular Member Basil's Avatar
    Nottingham
    Default Temp Related Cruise Control
    Hi all,
    Don't know if anyone else has noticed this on theirs, but the cruise control on my 1.9 CDTI SRi seems to be disabled until the engine has reached working temperature.
    I have tried a few times to call for cruise but it will only work once the temp needle has reached the first notch.
    Is it just the diesels that have this, or are all veccy's like it.
    Here, there and every where!
    Aaahhhhhhhh........so that's why.
    Can't say I've noticed it on mine (petrol) - but I also can't remember if I've ever tried to activate cruise control shortly after setting off!
    I'll test mine today Basil and let you know.
    Regular Member ion's Avatar
    walsall
    I've never noticed that. But then may not have tried as Duncan says
    Will have a go when I get chance.
    Mine works straight-from-the-off as well.
    There's usually a minimum speed (~30mph) below which you can't engage cruise control. Maybe that's your problem.
    walsall
    Tried mine, it works immediately.
    Regular Member Doug-SRidirect's Avatar
    Hemel Hempstead
    Mine works immediately too
    Doug
    Nottingham
    Quote Originally Posted by SJG
    No, I have tried that, even if I am doing 70 in top gear the cruise will not engage till the temp has gone to the first notch.
    Quote Originally Posted by Caterman
    Caterman, I take it by your reaction that your's is the same?
    Out of interest, what model veccy have you got?
    Regular Member Tim2100's Avatar
    Walsall
    Mine also works from cold.
    Chesterfield
    Remember that you can't use cruise control until the brakes have been applied for the first time on the journey.
    As soon as the brakes have been used then cruise should work. Does on mine anyway.
  1. Cruise control
    Last Post: 16th October 2009, 21:15
  2. Cruise control and engine temp issues
    By zerocool in forum Engine & Drivetrain
    Last Post: 3rd February 2009, 02:01
  3. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  4. Cruise control again!
    By Marty J CDTI in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2008, 19:21
