Results 1 to 10 of 11
Thread: vectra 1.8 immobiliser problems
    sheffield
    Default vectra 1.8 immobiliser problems
    every morning when i try to start car immobiliser sign in tacko lights up, after moving key in and out of ignition the flashing car with spanner through it comes up in takco after about five minutes car then starts up as anybody any idea what could be wrong with the car
    you'd be better posting this in the Troubleshooting section mate.
    I'll move it over there for you now Wayne (Thanks Alex).
    Quote Originally Posted by wayne64
    Sounds like the steering column transponder has given up the ghost.. had the same syptoms in my 'B' Gsi... Mine wasn't 'reading' the key..
    sheffield
    Thanks Mate Just Had Car On Tech 2 Found Problem Is Ignition Module (£250) Marvelous Warrenty Has Just Run Out
    Wayne, how far out of warranty is it? Is it time or mileage?
    sheffield
    july 31 st it ran out only done 33000
    Get onto Vx Cstomer Service. Explain the situation and that you're not very happy. You're only two months out of warranty (and your mileage is way inside the 60k) so see if they'll cover most of it as a goodwill gesture.
    My brother had a major engine part (oil cooler) go on his Vec B V6 and he was a couple of months out of warranty but well inside the mileage (like you). Vx ended up covering the vast majority of the cost and he only had to make a small contribution.
    Worth a try.
    Regular Member Basil's Avatar
    Nottingham
    That is bl00dy unlucky mate, you could try and get a goodwill gesture out of VX as it's only just out of warranty........but I wouldn't bank on it
    Nottingham
    Sorry for the DP but we must have posted at exactly the same time Duncan, and virtually the same answer...............Spooky
  1. immobiliser help
    By Tallywhacker in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2011, 18:04
  2. immobiliser 1.8Ls
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 11th June 2011, 14:06
  3. Immobiliser.
    By bigjoe in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2010, 17:06
  4. car immobiliser
    By mrpatterson2008 in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2010, 22:27
  5. Vectra C immobiliser system
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2007, 14:44
immobiliser vectra c
car immobiliser reset in sheffield
vectra c 1.8 immobiliser fault
vectra c immobiliser reset
https:www.vectra-c.comforumshowthread.php2080-vectra-1-8-immobiliser-problems
