Thread: No power after 3000rpm
    Regular Member Jamston39's Avatar
    Oct 2012
    Stockton on tees
    Trim : SRI
    Engine : 1.9cdti 150
    Mileage : 94500
    Default No power after 3000rpm
    Just tried to boot the car today and won't go past 3000rpm just seems to hit a wall but change gear and goes again to the 3000rpm any ideas what it could be
    Sep 2012
    Crawley
    Vehicle : Vectra SRi CDTi 150 Nav Estate
    Sounds like limp home mode, especially if it wont rev past 3k in neutral.
    Jul 2011
    teesside
    Engine : Z18XER
    I'm local to you if you need a code reader, in Billingham
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Any lights on?
    Oct 2012
    Stockton on tees
    Trim : SRI
    Mileage : 94500
    No lights on and nothing on the codes will try reving it in neutral now
    Oct 2012
    Stockton on tees
    Trim : SRI
    Mileage : 94500
    Will go to 4000 in neutral
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    You need it on diagnostics to view data before doing much else
    Quick check would be check all vac pipes
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Quote Originally Posted by Jamston39 View Post
    Does sound rather like one of the limp-mode limiters (there are two - a torque limiter and an IQ limiter and depending on the nature of the fault, one or both will be applied).
    It will allow up to about 3800rpm but torque limit drops significantly after 3000rpm hence in neutral it will reach nearly 4000rpm but under load it won't go much over 3000rpm.
    Like Critch says - need to get a fault code and ideally live data recording too in order to diagnose properly.
    Regular Member stuartbat's Avatar
    May 2008
    shropshire
    when I had my turbo I had this problem once it turned out to be the MAF that went faulty hth
    Oct 2012
    Stockton on tees
    Trim : SRI
    Mileage : 94500
    Checked again still no codes even live but abs light came on restarted car and gone off and power back but can't see why it was on at start up
  1. Problem past 3000rpm
    By DmccaC in forum Vectra C / Signum Troubleshooting
    Last Post: 13th April 2013, 19:15
  2. Wont rev over 3000rpm
    By RVESRS in forum Engine & Drivetrain
    Last Post: 5th July 2012, 12:52
  3. Wont go past 3000rpm
    By dannybutts in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2010, 18:08
  4. rumbling over 3000rpm
    By rec in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 08:40
  5. rattling noise after 3000rpm ??
    By rioni in forum Engine & Drivetrain
    Last Post: 24th January 2009, 10:34
vectra 1.9 cdti no power after 3000rpm
z30dt power loss above 3000rpm
