Thread: Fault codes with intention of getting a remap
    Regular Member Al 150 cdti's Avatar
    fareham hampshire
    Engine : 1.9cdti 150
    Default Fault codes with intention of getting a remap
    as above really Ive got Fault codes and they keep coming back. I`ve got the intention of getting a remap, would this affect the remap or would a Op com device if used to clear fault codes clear the map?
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Using op-com to clear codes will not harm a map, but I'd be thinking more about getting the codes sorted first before mapping. What codes do you have?
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Fix the faults you have first unless its obvisously to do with what a map can fix ie egr dpf etc
    fareham hampshire
    **********************ECU ID STARTS**********************
    Source Address: CIM
    Source Address: 0x00000245
    Identifier: 0x0015
    VIN:
    Part Number:13204146
    Software version number: 12244872_
    System description: DELPH0400
    Hardware key number: *27HELD
    Alpha code:
    Manufacturing date: 060822
    Code Index and version: 008 02
    Number of stored fault codes: 6
    B3794 - Switch Cruise Control Circuit Malfunction
    (08) - Not present
    U2103 - No Communication with CAN-Bus (High Speed)
    (00) - Not present
    U2105 - CAN-Bus No Communication with ECM (Engine Control Module)
    (00) - Not present
    U2108 - CAN-Bus No Communication with ABS (Anti-Lock Brake System)
    (00) - Not present
    U2111 - CAN-Bus No Communication With EHPS (Electro-Hydaulic-Power-Steering)
    (00) - Not present
    U2120 - CAN-Bus No Communication with AHL (Headlamp Levelling Device)
    (00) - Not present
    **********************ECU ID ENDS**********************
    Source Address: ECM
    Source Address: 0x000007E0
    Identifier: 0x0758
    System name: Z19DTH
    VIN:
    Hardware number:81013408
    Part Number:55205633
    Software version number: WJKMS070_S
    Hardware manufacturer number: 0281013408
    System description: 1037379428P319_O90
    System description: BOSCH0100
    Type approval number: B04003
    Hardware key number: ˙˙˙˙˙˙˙˙˙˙
    Programming Date: FFFFFFFF
    System description: 0x00006098
    Alpha code: ET
    Software version: O90JTD75
    ECU variant coding: 0x00003980
    Number of stored fault codes: 9
    P0070 - Ambient Air Temperature Sensor Malfunction
    (74) - Not present
    U2108 - CAN-Bus no Communication with ABS/TC
    (70) - Not present
    P0500 - Vehicle Speed Signal Range/Performance
    (7E) - Not present
    (7F) - Not present
    U2103 - CAN-Bus Circuit Malfunction
    (08) - Not present
    (06) - Not present
    U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
    (7F) - Not present
    P1815 - Cruise Control Interface Malfunction
    (72) - Not present
    (70) - Not present
    Source Address: ABS/TC/ESP
    Source Address: 0x00000243
    Identifier: 0x6003
    System name: ABS 430 NG
    Hardware number:0
    Part Number:12773671
    Software version number: 00C2E92D
    Alpha code: BS
    ECU variant coding: 0x00001918
    Number of stored fault codes: 3
    U2103 - <Unknown DTC>
    (00) - Not present
    U2105 - <Unknown DTC>
    (00) - Not present
    U2139 - <Unknown DTC>
    (00) - Not present
    Source Address: EHPS
    Source Address: 0x00000244
    Identifier: 0x0104
    System name: EHPS GEN3 TRW
    Hardware number:24444336
    Part Number:0
    Software version number: V21_
    System description: TRW 0300
    Alpha code:
    Code Index and version: 009 03
    ECU variant coding: 0x00000000
    Number of stored fault codes: 4
    (00) - Not present
    U2105 - CAN-Bus no Communication with ECM (Engine Control Module)
    (00) - Not present
    U2105 - CAN-Bus ECM Message Range/Performance
    (71) - Not present
    (00) - Not present
    Source Address: AHL/AFL
    Source Address: 0x00000249
    Identifier: 0x0410
    System name: AFL_Z3220
    Part Number:13184052
    Software version number: 60.05.01.01
    System description: VALEO0400
    Manufacturing date: 20060124
    Code Index and version: 002 06
    (71) - Not present
    U2100 - <Unknown DTC>
    (00) - Not present
    (00) - Not present
    (00) - Not present
    (00) - Not present
    U2143 - CAN-Bus No Communication with SAS (Steering Angle Sensor)
    (00) - Not present
    Source Address: IPC
    Source Address: 0x00000255
    Identifier: 0x1103
    VIN:
    Part Number:13193080
    Software version number: 3.40 10/05
    System description: VDO 0400
    Hardware key number: 0000000000
    Alpha code: QW
    Manufacturing date: 060821
    Code Index and version: 004 05
    (7F) - Not present
    (7F) - Not present
    (7F) - Not present
    Source Address: AIRBAG SDM
    Source Address: 0x00000257
    Identifier: 0x0102
    VIN:
    Part Number:13186947
    Software version number: 0C0D4B11
    Alpha code: KN
    Number of stored fault codes: 1
    U2139 - Invalid Data from CIM (Steering Column Module)
    (7F) - Not present
    Source Address: ECC
    Source Address: 0x00000248
    Identifier: 0x0301
    VIN:
    System name: SAC 3220
    Hardware number:13166480
    Part Number:13166481
    Software version number: 0ZF00/25C61
    System description: BHTC 04
    Alpha code:
    Manufacturing date: 20060904
    Code Index and version: 002 02
    No fault codes stored.
    Source Address: BCM
    Source Address: 0x00000252
    Identifier: 0x0209
    VIN:
    Part Number:13193590
    Software version number: D02D11 49041605
    System description: TEMIC04
    System description: 0x20202020202020303031353335323136
    Alpha code: NF
    Manufacturing date: 000600080206
    B3916 - No Communication With Alarm Siren
    (0F) - Not present
    Source Address: REC
    Source Address: 0x00000254
    Identifier: 0x0105
    VIN:
    System name: REC
    Part Number:13205774
    Software version number: 00000FA1
    System description: LEAR 0400
    Alpha code: FP
    Source Address: UEC
    Source Address: 0x00000253
    Identifier: 0x0105
    VIN:
    System name: UEC
    Part Number:13240244
    Alpha code: JF
    Source Address: DDM
    Source Address: 0x00000259
    Identifier: 0x0106
    VIN:
    Part Number:13193368
    Software version number: OP1D 193000
    System description: SIEM 0401
    Hardware key number: XXXXXXXXXX
    Alpha code: JQ
    Manufacturing date: 328060
    Source Address: PDM
    Source Address: 0x00000258
    Identifier: 0x0105
    VIN:
    Part Number:13193369
    Software version number: OP1D 192000
    Alpha code: JR
    Source Address: EHU
    Source Address: 0x00000241
    Identifier: 0x0504
    System name: CDC 40 OPERA
    Hardware number:13188432
    Part Number:13188475
    Software version number: 09.05/-----
    System description: BOSCH0400
    Alpha code: LN
    Manufacturing date: 20060829
    Code Index and version: 023 01
    Audio Index and version: 043 03
    Source Address: DIS
    Source Address: 0x00000246
    Identifier: 0x1201
    VIN:
    System name: CID/GID Epsilon
    Hardware number:13128260
    Part Number:24461295
    Software version number: GE59-/00050
    System description: SIEM 0400
    Alpha code: DD
    Code Index and version: 002 01
    Number of stored fault codes: 2
    (71) - Not present
    U2201 - CAN-Bus No Communication with EHU (Entertainment Head Unit)
    (00) - Not present
    Source Address: EHS
    Source Address: 0x0000024D
    Identifier: 0x0101
    System name: DAB 45
    Hardware number:13111066
    Part Number:13111066
    Software version number: 01.33/rel60
    Alpha code:
    Manufacturing date: 20060818
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Have you tried clearly them? Codes are not present.
    fareham hampshire
    Yeah all been cleared twice now dials used to go aswell but that was cured by abit of cleaning connectors. going to try the earth mod as see if that helps
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Remove an clean abs module plug
    Nov 2009
    newcastle
    when you get remap make sure they give you latest edition of software from vx and remap that not remap existing . found the 05 software was improved for smoother running and fault finding. turned out vx didnt tel the ecu what a lot of items were so didnt show as faults, the dpf self cleaned at wrong settings (too high) so didnt clean enough etc. just a simple update improved a lot when a remaped
  1. p1792-71 gearbox fault code plus alarm sensor fault codes
    By stu f in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2013, 21:05
  2. Fault Codes
    Last Post: 28th April 2012, 19:02
  3. 3.2 Gsi fault codes
    By Spelly in forum Engine & Drivetrain
    Last Post: 4th May 2011, 16:55
  4. fault codes
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2011, 10:20
  5. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
https:www.vectra-c.comforumshowthread.php186618-Fault-codes-with-intention-of-getting-a-remap
opel signum no communication with ahlu2105-71 can bus ecm message rangeopel vectra c d u2108u2103 - can-bus circuit malfunctionVauxhall vivaro DTC U2108-00opcom code u2103z19dth u2103z19dth u2103-04Opel vivaro DTC U2108-00
