Results 1 to 10 of 15
Thread: egr blabking and cheater install on vec c 2.2
    Apr 2013
    United Kingdom
    Vehicle : vectra c
    Trim : sri
    Engine : 2.2
    Post egr blabking and cheater install on vec c 2.2
    i looking for a bit of advice on fitting my cheater for the egr. can anybody help me please?
    just need to know how the cheater is installed.
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Is it the SE or YH? Don't think you need the cheater, def don't on the SE, just the plate and leave the EGR connected
    Hanging Heaton
    35 Post(s)
    Mileage : 140k
    Just seen yours is the SE so you don't need the cheater, put in the plate then spin the EGR so that the mech over hangs the plate to avoid fowling, still need to be connected as it still needs to work etc, but it will be fully blanked with no EML
    Apr 2013
    United Kingdom
    Vehicle : vectra c
    Trim : sri
    Engine : 2.2
    orite i see i thought that i needed the cheater to remover as the egr is faulty hence the blabking off
    Hanging Heaton
    35 Post(s)
    Mileage : 140k
    If its faulty then you may need it, I'm unsure, but I'd still be tempted to blank without first... Do you have the EML on now and is it def the EGR... You need to head over to the Z22SE forum, shows you how to solder it in on there if its needed
    Apr 2013
    United Kingdom
    Vehicle : vectra c
    Trim : sri
    Engine : 2.2
    ok then mate nice one ill have a look on there as well and will update when done
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    If the EGR isnt working then you need the cheater. The newer cheaters are plug and play so no need to solder, just unplug the egr and plug in the cheater. First off try cleaning the egr and testing it by passing 12v over pins A & E. If it doesnt pop in and out like in the vid then its ferked. HTH
    Regular Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    What are the benefits from blanking it?
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by tubby View Post
    Not a great deal in a Z22SE tbh mate. The side affects would be a cleaner intake which would be very beneficial in a Z22YH and slightly worse mpg as the egr is only open when the car is cruising and not at WOT. If your egr is sooting up and sticking then blanking would obviously stop that from happening.
    On YH however it should help keep the swirl flaps cleaner and free moving.
    HTH.
    Sent from my Nexus 7 using Forum Runner
    Apr 2013
    United Kingdom
    Vehicle : vectra c
    Trim : sri
    Engine : 2.2
    nice one will check it oit and the cheater iv got is off z22se.co.uk is that a plug and play??
  1. install done
    By andy76 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd August 2012, 16:42
  2. new install in the vec
    By bensterzback in forum Quick Photo Album
    Last Post: 18th October 2010, 21:10
  3. sub and amp install
    By Sp33dy in forum Electrical & ICE (including SatNav)
    Last Post: 8th July 2010, 21:07
  4. My install!
    By smiley-sri in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2009, 22:44
  5. My little ICE install
    By bensterzback in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2009, 20:08
vauxhall vectra c 2.2 sri egr
