Thread: parking sensors
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    Default parking sensors
    i fitted the std after market parking sensors a few yrs ago
    i have just got a replacement set but have gone for the ones with a display screen to show distance and left and right sense
    just want to know were to put the display
    if any one has used a similar kit can you tell me or show a pic please
    Regular Member djr69uk's Avatar
    Midlands
    I wanted to be able to see mine easily when I turned around to reverse, so ended up sticking it to the shoulder of the passenger side rear seat next to the seat release lever and hiding the wiring under the shelf and then into the rear fuse box compartment. I have to remove it when I put the seat down but it isn't very often and it sticks straight back onto the plastic surface. It's an effective place as you can see the screen clearly each time you turn around.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I have, and I put mine on the top of the steering wheel shroud. Problem with that is, with the wheel half turned, the spokes block the view of the display. Was thinking of trying it in the right corner of the dash top.
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    I've been looking at these kits after missing my factory PP, will it not go in the cubby hole?... Sure someone put similar in the interior alarm sensors, looked good
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Yeah lee sure he posted a how2 on that... i put mine on the dash right in front of the steering wheel.
    Feb 2011
    Selby
    Yep - lots of threads on this subject. I fitted on of the ones that was £8.99 a couple of months ago, with the distance and left/right bar graph displays. I put the display in the cubbyhole under the heater controls. Drilled a hole in the back of the cubby unit to allow the cable to pass through and ran the cable under the centre console, past the gearstick and out under the front passenger seat across to the sill cover, then past the back seats and into the boot. Very easy - just unclip the gearstick surround and pull the gaiter up, pull out the cubby hole, ashtray and cup holder and unclip the rear seat side bolster enough to get the cable past. No tools needed
  1. parking sensors
    By chris1804 in forum Electrical & ICE (including SatNav)
    Last Post: 10th June 2012, 11:59
  2. parking sensors
    By gizmo10119 in forum Bodywork & Interior
    Last Post: 15th May 2012, 21:46
  3. Which Car Parking Sensors?
    By Deann in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2011, 14:25
  4. Parking Sensors
    By Mark2.2 in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2010, 21:01
  5. Parking Sensors! Help!
    By Schui1024 in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2009, 23:52
