Thread: 2.2DTI SRi Oil pressure light blinks
    Mar 2013
    Barreiro
    Trim : Vectra C GTS
    Engine : 2.2 DTI
    Default 2.2DTI SRi Oil pressure light blinks
    Fellas,
    I'm sorry for some time apart, but i was a few weeks out in work. Now i have an old issue bugging me again. At September every time i did a long or difficult trip like climbing on my SRi, the oil pressure light blinked on neutral. Running cold it never happened. A technician had measured the oil pressure and said that's ok, so we've seen the electrical part. After a reset on ECU i did some long trips (at about 500miles always running), and the oil pressure light no longer blinks. But on easter i think it had blinked once after a lot of effort to get out of being stuck on sand. What do you recommend me to do? I'd seen prices of oil pressure switch and oil temperature sensor and it's not expensive(at about 20€). Someone has another idea?
    Thanks a lot,
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    if a mechanic has tested the oil pressure and the pressure is ok then you need to fit a new oil pressure switch.what mileage have you done since the oil and filter were changed.
    belgium
    this happens also when oilfilter is clogged up.
    Mar 2013
    Barreiro
    Trim : Vectra C GTS
    Engine : 2.2 DTI
    Quote Originally Posted by jonnybravo View Post
    Yes...i spoke to my uncle (the family's mechanical...works on Peugeot/Citroen here at Marinha Grande) yesterday at dinner and he said that he didn't remember the exact value, but surely higher than 0.4 bar. When it happened last time it was just before the oil and filter change...I think at about 9300 miles(15000km).
    Quote Originally Posted by daywalker072 View Post
    I always change the filter when I change the oil, so all oil filters that were in my car didn't run more thar 9300 miles. The filter fitted in the car has 300 miles now.
    I'm going to France in May 6th, and i will measure the oil pressure and change oil pressure switch just in case...it's cheap. 7€ don't pay doing that trip worried.
  1. Replies: 26
    Last Post: 14th March 2014, 01:03
  2. oil pressure light
    By Tank988 in forum Engine & Drivetrain
    Last Post: 15th March 2013, 00:06
  3. 2.2dti spanner light at idling?
    By bigben in forum Engine & Drivetrain
    Last Post: 27th January 2010, 21:05
  4. 2.2DTI Spanner fault Light.... HELP
    By n30jjb in forum Vectra C / Signum Troubleshooting
    Last Post: 15th June 2009, 08:42
  5. 2.2DTi Engine Management Light
    By MicSignum in forum Engine & Drivetrain
    Last Post: 19th April 2008, 14:39
https:www.vectra-c.comforumshowthread.php186030-2-2DTI-SRi-Oil-pressure-light-blinks
opel 2.2dti AC referent presure
vectra c 2.2dti oil pressure switch location
2.2direct oil pressure sensor
vauxhall 2.2 direct oil pressure sensor
oil pressure sensor opel zafira 20 dti
opel 2.2 dti oil pressure trouble
vectra 2.2 Dti oil pressure sensor location
movano 2.2 dti oil pressure light
vauxhall vectra 2.2 flashing oil light
opel 2.2 dti minimum oil pressure
opel vectra c y22dtr oil pressure sensor place
oil pressure y22dtr
opel signum flashing oil sighn
opel zafira 2.2 dti oil senzor
vauxhall vectra oil pressure light
where is oil pressure switch on vauxhall vectra c 2.2dti
vectra oil light blinks
vauxhall 2.2 dti oil filter after change the oil
vectra dti oil pressure
vectra c 2.2dti oil pressure sensor problems
vectra c oil pressure light
opel zafira 2.2 pressure switch 2008
vectra c 2.2 direct oil light
2.2 dti vectra low oil pressure at idle
