Thread: Engine Stalls under Braking
    Mar 2013
    Wiltshire
    Engine : 1.9 CDTi
    Default Engine Stalls under Braking
    Hi noticed yesterday ( Same time I was told about the my brake lights flashing , separate post here ), that the car stalls wen the brake pedal is used. I had some issue with it irractically reving so unplugged the EGR that issue went away now this 1 has arisen. ( I've cleaned EGR and plugged it back in and not noticed that problem again. Yet! ) I Drove to work and it stalled a few times under braking for turning junctions and I sat out side and had car running, depressed brake pedal and after 3-4 seconds the car stalls. Starts up fine again after. Any 1 have any ideas?
    Jan 2012
    Gloucestershire
    Vacuum pump or vacuum servo fault? The pump provides the vacuum for both the brakes and turbo wastegate - can't think of anything else (not knowing enough about the electrical systems) that could link the brakes and idling/general engine systems.
    Mar 2013
    Wiltshire
    Engine : 1.9 CDTi
    other fault im having with the car at the same time
    http://www.vectra-c.com/forum/showth...42#post2035942
    Mar 2013
    Wiltshire
    Engine : 1.9 CDTi
    I have unplugged the Brake pedal switch, and the car doesn't stall when pedal depressed. Plug I back in and the car stalls again wen brake depressed. Brought a new switch, and no difference, still stalls and works ok unplugged. Brake lights are flashing like the emergency brake setup but Im not touching the brake pedal as its doin it.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Check all crank case breathers
    Mar 2013
    Wiltshire
    Engine : 1.9 CDTi
    ok, problem sorted. the wiring loom clip had broken on the air filer box resulting in it dropping down next to the cambelt which in turn tore through the cabling. Hence to say I had about 10 bare wires all shorting and giving me jip. all fixed now though. Thankz for your input
  1. Cdti 150 starts and stalls
    By srbrian in forum Engine & Drivetrain
    Last Post: 5th January 2013, 21:42
  2. Insignia 2.0 CDTi - engine braking ???
    By vxinsigniaboy in forum Insignia car chat
    Last Post: 15th August 2011, 21:37
  3. Vectra c 3.2 Stalls
    By Vegetable in forum Electrical & ICE (including SatNav)
    Last Post: 5th April 2011, 10:00
  4. Replies: 3
    Last Post: 6th July 2009, 11:04
  5. Engine cutting out when braking
    By ash_scotland88 in forum Engine & Drivetrain
    Last Post: 29th May 2008, 21:16
https:www.vectra-c.comforumshowthread.php186010-Engine-Stalls-under-Braking
