Thread: fitting vxr diffuser
    Jul 2011
    UK
    Year : 06
    Default fitting vxr diffuser
    Anyone know how to fit one and best way will be doing it while car on ramp getting exhaust
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    I found the best way was to take the bumper off the car. This way gives you plenty of room to work. As for fitting it just clips into the existing holes that the sri one fits to you`ll also have to cut the two brackets that hang down from the bumper that the sri diffuser fits to..HTH
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    I changed mine with the bumper on the car (less work and not as time consuming)
    I pulled the single sri diffuser off (broke it as it had a little mark on it anyway)
    Pushed the vxr diffuser on and gave it a little tap with a rubber mallet wrapped in a soft cloth for those clips that needed a bit more force to seat them in the bumper.
    As for the things that hang down, i Fitted it properly and re-used the push clips and clicked them into the plastic brackets on the bumper bar.
    Its hard to go wrong
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    its easy on a normal bumper you wanna try it on a car with a xp2 kit mine was a ****
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Its not that bad if you remove the rear splitter
  1. removing and fitting rear diffuser
    By MURDO in forum Styling
    Last Post: 17th August 2012, 23:06
  2. Fitting vxr rear diffuser to sri xp
    By 2.2 oil burner in forum Styling
    Last Post: 18th July 2010, 11:55
  3. Fitting VXR Diffuser
    By coddy2200 in forum Styling
    Last Post: 18th May 2010, 16:57
