Thread: Sri front springs
    Sep 2009
    goole
    Default Sri front springs
    hi just had vectra sri xp in for mot and front 2 springs broke the garage put 2 on but when picked up car looked too high i asked them and they said they r the right ones,was wondering if anyone knows if the sri should have shorter ones on as t sit lower been a sri model.as been around looking at other vectras and they all look as tho they sit lower than mine would be be greatfull for any help thanks.
    Regular Member owen_999's Avatar
    Aug 2012
    Hartshorne
    Vehicle : Vectra SRI 150
    Trim : SRI
    Engine : 1.9cdti 150
    Sri are 15 mm lower than a standard vec I believe
    Sep 2009
    goole
    thanks and as any one else got any information as car looks rubbish like it is measurred from centre of wheel and it measurers 37cm should it be less than this the car is sri xp 1.9cdti need some help and advice as need t have it out with garage that put them on thanks anyone.
    Aug 2012
    Hartshorne
    Trim : SRI
    Unfortunately vx has stolen my car back otherwise I would of gone out an measured to compare but think best bet is either someone on here will know the dimensions or you might be able to see one about and just park next to it and look at the heights. Typically the front is slightly higher than the rear though.
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    mine was high on the front all the others have prob got broken springs lmao
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Just measured mine for you, 37.5mm from wheel centre to arch. 1.9 sri.
    Sep 2009
    goole
    Thanks stevoxsi what size wheels u got on as mine 19" snowflakes .
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Perhaps yours was lowered as well before
    Dec 2011
    Seaham
    The springs will take a little time to settle.
    East Ayrshire
    Trim : SRI XP1
  1. Front springs
    By farnorth in forum Suspension, Wheels & Brakes
    Last Post: 1st July 2009, 17:19
  2. front springs
    By micks edition 100 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2009, 18:41
  3. Front Springs - How Much?
    By sophos9 in forum Suspension, Wheels & Brakes
    Last Post: 10th May 2008, 21:27
  4. HELP front springs
    By John35 in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2008, 20:02
vectra c sri front springs
