Results 1 to 3 of 3
Thread: fuel pump vec c
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default fuel pump vec c
    hi, im assuming the vec c is the same as the b, under the rear seat is a large plastic disc, under that will be a metal plate which you have to spin slightly to release, am i right, want to drain the derv, well over half a tank in my scrap car, il syphone it out, id rather do that than cut any fuel lines, more control, is it the same way
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    there is a circular access point there as you say, it gives you access to the tank and the fuel pump. I do know the petrols have pumps in the tanks, no sure about the dervs as i have not had a play with one yet.
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    its there, same as the b, moved it out the way and got 35 ltrs out, result
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. Replies: 19
    Last Post: 30th May 2012, 15:53
  3. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  4. 2.0 DTI Fuel pump
    By lucvh in forum Diesel Engine related
    Last Post: 15th October 2009, 20:27
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
