Results 1 to 10 of 20
Thread: Lowering springs Confused
    Regular Member Al 150 cdti's Avatar
    fareham hampshire
    Engine : 1.9cdti 150
    Default Lowering springs Confused
    Hi all,
    bit of a newbie to lowering.
    car Vectra c 150cdti design with xp kit 18inch wheels 235/40/18.
    been reading alot on lowering springs, my rear spring has gone.
    recently had the rear arb bushs changed, rear drop links, upper control arms, blisten b4s.
    I would like your advice on whether to choose
    Amax springs made by spax?
    Fk springs
    LO 45 springs
    H&R springs etc
    and do I need under 1000kg or over 1001kg
    Many thanks
    Regular Member simmo3187's Avatar
    Jul 2010
    North Wales/North West Border
    Engine : 3.0 V6 CDTI
    Don't go near A-Max mate, stay well clear as @paulvectrac will tell you
    Go with either LO springs, H&R's or Eibachs
    Under 1000kg is what you need
    HTH
    fareham hampshire
    Really are A-max that bad? what difference are the weights for if you dont mind me asking?
    Jul 2010
    Its the axle weights
    For example, i've got v6 cdti which is heavier front end than say a 1.9 cdti like yours
    A-Max are fairly shocking, in fact I've got some waiting to go back to EuroCarParts as they sent me A-Max instead of Apex!!
    fareham hampshire
    If I put the higher weight springs on what would the difference be? going through most websites it says mine is 1000kg plus ... Shift+R improves the quality of this image. CTRL+F5 reloads the whole page.
    Jul 2010
    Thats weird because when I bought my Apex ones they had 2 part numbers
    One's for under 1000kg and ones over 1000kg, obviously mine showed the heavier ones due to the v6
    Take a look on the sticker thats on the inside of the drivers door for the weight, I think its the 3rd figure down
    Actually thinking on I think the load for the front axle on the 1.9 150 is 1080kg so you will need the over 1000kg ones
    fareham hampshire
    Thanks, just checked 1065kg
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Just been looking around and motorsportworld are doing the H&R 40mm springs (so probably more like 25mm lower than a factory lowered SRi) for £158 with a tenner delivery - link: http://www.motorsportworld.co.uk/det...-2&PID=1071379
    Dunno if they're a good retailer or not though, I've never dealt with them.
    Kildary, Highland
    I put H&Rs on my Signum Design, similar to stock SRi suspension and my car looks so much better now. Well made springs too - I can recommend them and at the price you've seen them, I wouldn't bother with anything else.
    fareham hampshire
    I was just going to order some LO 30mm springs, now youve made me think twice has anyone got pictures of the H&R 40mm springs on there vec?
  1. ok am confused springs
    By marc vectra sri in forum Suspension, Wheels & Brakes
    Last Post: 17th February 2013, 15:24
  2. lowering springs
    By davedave in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2012, 11:27
  3. lowering springs
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2012, 20:35
  4. Lowering Springs, im confused!
    By VXR CDTi in forum Styling
    Last Post: 15th February 2009, 19:55
