Results 1 to 2 of 2
Thread: factory fit satnav fitting parts
    newport
    Default factory fit satnav fitting parts
    asking on behalf of the father in law.
    he has a 58 plate sri with the cd30 stereo and 3 line dot screen with mpg etc on.
    what exactly would he need to fit the factory sat nav stereo and screen
    i would assume:-
    stereo with paired screen
    vents surrounds to match the screen.
    nav disc
    but what else? do you need different/additional cabling, aerial etc
    is it all plug and play? or would anything need activating or splicing into wiring?
    how does the disc work? does it have to be in to use the satnav or is it only for uploading the maps to the stereo?
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    You'll need a FAKRA GPS aerial, as well as the RGB cable that goes between the screen and the CD70 (but it should be included if you're buying the screen and headunit as a pair).
    Other than that, you've listed all you need. If you get a later version, you might also want the little pocket (under the heater controls) with the AUX in jack, but apparently it's a bit rare and hard to come by.
    As far as I'm aware, the nav disc stays in the lower drive to give you the navigation function.
  1. fitting a garmin satnav in place of cd30 gid screen?
    By Jow20 in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2012, 23:07
  2. Fitting 2nd hand Vectra C satnav (I don't have any codes)
    By chodecz in forum Electrical & ICE (including SatNav)
    Last Post: 14th November 2009, 18:48
  3. Fitting satnav
    By declanswan in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2009, 18:56
  4. Factory fit parkpilot kit. complete Fitting instructions
    By Big-Pete in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2007, 12:40
  5. Fitting Sony Head Unit in place of Factory CD30
    By FACUP76 in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2006, 18:55
