Thread: Z20net Vacuum pump leaking oil
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default Z20net Vacuum pump leaking oil
    Hi guys had car jacked up today and noticed oil on the bottom of my gearbox upon inspection it appears that it is coming from my vacuum pump on the side of the engine i think the gasket might have failed would this be the case or does this generally mean i need a new one.
    South east
    Try the rubber gasket first, it's easy to change.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Cheers mate you wouldn't happen to know the part number would you
    South east
    55561100 - a rubber band that looks like the outline of Africa.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Cheers mate is it an hard job to do will it leak oil bad once I disconnect it
    South east
    Fairly easy, and there won't be much oil. You have to remove the electronic module that's bolted to the front of the vacuum pump, then unbolt the pump itself, fit the new gasket and reassemble.
  1. vacuum pump cdti
    By mon in forum Engine & Drivetrain
    Last Post: 23rd January 2013, 09:31
  2. vacuum pump leak... :(
    By geleziux in forum Vectra C / Signum Troubleshooting
    Last Post: 25th May 2011, 21:22
  3. How to test the vacuum pump?
    By andreitone in forum Engine & Drivetrain
    Last Post: 17th February 2011, 07:13
  4. vacuum pump
    By Dougb in forum Engine & Drivetrain
    Last Post: 30th June 2010, 22:41
  5. EML - Vacuum Pump ?
    By matiny2k in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2008, 20:53
https:www.vectra-c.comforumshowthread.php184848-Z20net-Vacuum-pump-leaking-oil
z20net vacuum pump oilz20net vacuum pump failz20net vacuum pump gasket
