Thread: HID Light problem
    Regular Member conman's Avatar
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    Default HID Light problem
    Hey guys, I've had my HID's in for a few months now and last night when driving home the bulb error light came on and my driver side bulb was out. I then turned the lights off and back on and both lights came on but a few seconds later the same bulb went out again. Tonight I was driving home on the same route and the same happened again around the same length of time which was about 3 mins into driving. The same thing happens when I turn them off and on again, works for about 3 secs and then off again.
    Just wondering could this just be a bulb issue or would it be the ballast? I'm going to change the bulbs tomorrow but if it is the ballast they have a 2 year warranty but don't have a spare ballast so will have one light until I get a replacement which is a bit of a hassle although as it ain't working anyways I suppose it's same difference....lol.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Disconnect bulbs and check its clean, vaseline then fit it back on.
    With bulbs, i always carefully position and slowly push it in. As if do it quickly, it can bend the sockets and tend to weaken the contacts
    Just a thought.
    13 Post(s)
    Quote Originally Posted by conman View Post
    don't have a spare ballast so will have one light until I get a replacement which is a bit of a hassle .
    Can't you just stick a halogen bulb back in? Have you not got the ones your took out when you changed over to the HIDs?
    That's what I did when one of my HID bulbs failed a while back. Only had to take the 2 spade terminals out of the headlight socket connector and plug straight onto the H7 bulb.
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    I tried 2 new HID bulbs in and the same thing is happening so I guess it's a faulty ballast after all. Just put the old halogens back in and they work fine and took the faulty ballast out and contacted Hid's Direct to sort out a replacement, no word from them yet but my guess is they are closed for Easter. Hopefully there shouldn't be any problems getting it sorted.
    Dec 2011
    Seaham
    Have you had HIDs activated?
    I understand that even with canbus cancellers etc, you can still have issues with some cars.
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Quote Originally Posted by Ben50n View Post
    I have a pre-facelift with HIDs fitted. Not had them activated and have had no problems. I have the CANBUS PRO set from HIDs Direct, with cancellers fitted.
    I would think it's the ballast at fault, as you've surmised already. HIDs Direct were pretty good when I exchanged my original ballasts for the CANBUS PRO ones, just be patient, they seem to be a 1 man band.
    crook
    Faulty ballast mate
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The standard fault-find for this kind of problem is to move individual components from one side to the other and when the fault suddenly follows, you've found your dodgy component.
    But given all that's been said it's certainly sounding as though you have a faulty ballast.
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    I have the HID's set to "Present" and had no bulb warnings. I noticed if I did switch it to "Not present" I got bulb failure errors until I changed the setting back again regardless of them coming with cancellors. I think this depends on which model of Vectra you drive so hit and miss whether or not you have bulb warning problems no matter what kit you use as I put in a set off cheap balasts with no cancellors and had no error with them either as long as the car had Xenons set to "Present"
    Anyways, I have since had the faulty ballast replaced by HIDS Direct with no questions asked but just haven't got around to putting the good ones back in as it's done nothing but rain over here, so next half decent day I'll whip the bumper off and get the lights back to normal
    Cheers for the replies, much appreciated guys
  1. Fog light problem
    By VikingLammy in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2012, 20:00
  2. Rear Signum Light problem problem - help
  3. EML light problem
    By CraigoT in forum Engine & Drivetrain
    Last Post: 20th April 2012, 19:14
  4. HID light problem
    By JSYSH466Y in forum Styling
    Last Post: 19th April 2009, 00:16
  5. Problem - ABS light is on!!
    By pamsie36 in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2008, 18:16
