Results 1 to 10 of 11
Thread: Inlet manifold
    Regular Member kamar's Avatar
    bradford
    Default Inlet manifold
    Hi I've decided to get a new inlet as the old one has had it's days. I'm getting around 30 mpg. Sluggish under 2k rpm. And smell through my heater vents. I was after feed back from guys who have had this replaced and what difference they noticed. E.g power wise. Mpg etc.
    Regular Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    19 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    Well, I've not had mine done but from my knowledge of engines it will definitely use the fuel more efficiently, giving you a bit more power at the lower revs
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    Ive done loads for people and always had people saying there car feel loads better and slightly better mpg
    Regular Member LGaffer's Avatar
    Dec 2012
    Castleford
    5 Post(s)
    Vehicle : Vectra C Preface
    Trim : SRI
    Engine : 1.9 cdti 150
    I did mine myself at the beginning of february. Like you i was getting poor mpg, sluggish and exhaust smell through vents. I replaced the inlet with new gaskets for the egr and throttle body too. The car now starts, idles and runs a lot better now and the mpg has increased massively. One other thing is make sure you buy the actuator connecting rod as these tend to break on removal so a new one is a good idea. Only cost me about £6 from dealers
    bradford
    That's great thanks. The mechanic I use is on holiday from 5 April for a month so I've got it booked in for when he gets back. Also did u guys buy the inlet from dealers or from eBay. Pierburg makes are available at around £160.
    Regular Member shinyb1's Avatar
    Jul 2011
    wigan
    i bought mine from general traffic , genuine pierburg ( updated one ).
    bradford
    Any chance of part number so I know which I am buying. (When someone has spare minute)
    Regular Member pattz123's Avatar
    Motherwell
    17 Post(s)
    Vehicle : Vauxhall Vectra Estate
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 83k
    55210201 just replaced mine at the weekend, doesn't smoke on start up any more but haven't noticed any increase in power and mpg slightly better. Not a bad job to do but not for the faint hearted.
    bradford
    Thanks mate. Mine smokes abit on start up and poor mpg. If I put my foot down there isn't much smoke and it still seems to pull strong. But the smell that comes out of heater vents is now bad. £35 diesel 140 miles local till light comes up..
    Motherwell
    17 Post(s)
    Trim : SRI
    Mileage : 83k
    Replacing the manifold should cure your smokey start up but I never had a problem with exhaust smell through the vents as Ive been venting the crank fumes to atmosphere for about 2 years now, saves all the oily fumes going back through the manifold as it does breath quite heavily at times.
  1. Inlet Manifold
    By Quirrel in forum Engine & Drivetrain
    Last Post: 23rd January 2012, 12:59
  2. inlet manifold
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2011, 22:07
  3. 1.9 150 Inlet Manifold..
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 20:29
  4. Inlet manifold what do I need
    By sebadee in forum Engine & Drivetrain
    Last Post: 6th March 2011, 00:41
  5. New Inlet manifold?
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 8th November 2009, 23:06
