Thread: Water ingression problem
    Regular Member bighammerfan's Avatar
    hillingdon
    Default Water ingression problem
    Hi all. Im having trouble with water getting in somewhere in the vboot area. Every so often I have to take the spare wheel out and remove an inch of water from the bottom of the spare wheel well. Am I right in thinking its coming in through the rear quarterlight windows ? The carpet is getting a tad mouldy and it seems like the inside sides of the boot are damp
    Alan
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Could be any number of places unfortunately,but that's a good place to start,hope its not comin in through the aerial base,then you'll need to drop the roof lining bt the rear to gain access
    hillingdon
    Ok thanks. if its the windows i guess siliconing round them will sort it out
    Jun 2011
    Vehicle : vectra
    Year : .....
    I believe you can take them out put some sealer in and replace,they're held in with screws not much of a job but never done it,just know through reading on here
    hillingdon
    oh ok thanks for the info
    Jun 2011
    Vehicle : vectra
    Year : .....
    No probs fella sorry I can't be of more help ;-)
  1. 2.2 se water pump/ temp gauge problem.
    By james chambers in forum Engine & Drivetrain
    Last Post: 29th June 2012, 20:31
  2. Water, Coolant & Heater Problem
    By tris_hill in forum Vectra C / Signum Troubleshooting
    Last Post: 28th March 2011, 14:24
  3. Possible water pump problem
    By mr.c72 in forum Engine & Drivetrain
    Last Post: 15th July 2010, 19:55
  4. Water Pump Problem?
    By mattster87 in forum Engine & Drivetrain
    Last Post: 8th May 2009, 21:14
  5. hatchback water problem?
    By pyro_maniac in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2007, 15:30
