Thread: swirl actuator problem
    Jun 2011
    machynlleth powys
    Default swirl actuator problem
    Hi people. I have no power on low revs car barely moves got home lookes at the swirl and there loose with oil residue around them when it revs they move but smoke poars out ftom where they sit.
    Im gathering I need a new intake manifold??
    Hope im wrong
    Help much apreciated.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Regular Member pattz123's Avatar
    Motherwell
    17 Post(s)
    Vehicle : Vauxhall Vectra Estate
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 83k
    Sounds like you could also have a seized egr valve as you wouldn't lose full power with a knackered manifold, I had same issue last year and after stripping egr I found the solenoid pin jammed out but repaired it easily following the "how to" on here, worth a punt checking there first to restore some power, I found it scary at junctions nearly getting t boned. Just happens that I'm replacing my inlet manifold this weekend after taking over a year to pluck the courage to attempt myself.
    Jun 2011
    machynlleth powys
    Quote Originally Posted by pattz123 View Post
    I cant explain the smoke coming from the swirl bar area theres oil residue arround the valves ??
    Motherwell
    17 Post(s)
    Trim : SRI
    Mileage : 83k
    Yes you will need a new manifold but I don't think it's the cause of your complete power loss, as of Tony's post you could do his fix which would seal the manifold with the flaps open but you would be down slightly on fuel economy as your probably experiencing now, best solution would be to replace but it's whether you have funds available. Good luck
  1. Swirl actuator
    By carl78 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 11:44
  2. Swirl pot actuator
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 21st November 2009, 01:00
  3. swirl actuator problem
    By ziggi in forum Engine & Drivetrain
    Last Post: 30th September 2009, 03:34
  4. Swirl Actuator Problem... or not?!
    By djr69uk in forum Engine & Drivetrain
    Last Post: 2nd May 2009, 21:18
  5. Swirl Actuator Problem... or not?!
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2009, 19:50
