Thread: LED Parkers throwing up blown bulb signal!
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    Default LED Parkers throwing up blown bulb signal!
    As above ive replaced the front parkers and number plate bulbs with bright white LED bulbs today and they are all working but still its showing up on the dash that the parkers are blown. I tried changing them opposite way around but the warning light only goes off when i put the standard bulbs back in. Has anyone else had this issue?
    Regular Member johnny kebab's Avatar
    May 2007
    Leighton Buzzard
    Everyone does, LED bulbs don't have enough resistance for the bulb check systems.
    JK
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    You will need some resistors on them.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    You can can bus compatible led 501 bulbs off ebay they have a built in resistor but they will still flash when driving and every so often when vehicle is locked.
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    ive just had a look through the forum and seen this is common alright, mabey i should have looked first
    I noticed them flashing aswell! i changed them back as couldnt stand the warning on the whole time, are these the type i need?
    http://www.ebay.co.uk/itm/CANBUS-LED...item5193d99b1d
    Feb 2007
    Norfolk
    go for mtec 501 bulbs. OK not LED but you won't get strobing effect or any errors.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    1.50 worth of resistors from maplin an 15 mins o your time will sort it
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    From experience, the MTEC 501s are awful. Nice colour to them, but so dim they are hardly worth bothering with. Changed mine to some Phillips Blue Vision bulbs, which are much better in my opinion.
    Apr 2012
    London
    Trim : SRI XP2
    Engine : 1.9CTDI
    Hi All
    I have bought theses an no flashing
    http://www.ebay.co.uk/itm/2710431607...84.m1497.l2649
  1. blown headlight bulb
    By b1lly in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2012, 11:15
  2. blown headlight bulb
    By b1lly in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2012, 22:39
  3. hid bulb blown
    By n8sby in forum Styling
    Last Post: 12th March 2011, 21:39
  4. does a blown bulb cause other problems?
    By admob in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2010, 22:04
  5. Bulb blown!
    By Vectra Singh in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2008, 18:57
