Thread: Any MS Excel gurus here?
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    Default Any MS Excel gurus here?
    Ive made my own spread sheet to chart the weights of our newborn puppies and wanted to add a formula that displays the increase in weight from the 1st birth weight. The spread sheet ive done is below
    Can anybody help me to write the correct formula that will show the increase from day 1, not sure where i can put the result so suggestions for location would also be good.
    Thanks for any advice in advance
    cheers
    Regular Member Paulwr's Avatar
    Mar 2012
    Ormskirk, Lancs
    Vehicle : Astra H 1.8 VVT
    Trim : SRi XP 3dr
    Engine : Z18XER
    Mileage : 12k
    Hi
    Step 1 - remove the G from the weight columns so excel recognises the value as a number
    Step 2 - insert another column after the puppy column, e.g. insert a column after B, C, D etc
    Step 3 - insert the formulae =B4-$B$3 into the new column, this will show the difference from birth weight to current weight
    A B C
    1 Date Puppy
    2 weight in g Increase
    3 23-Mar 100
    4 24-Mar 105 5
    5 25-Mar 110 10
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    Is there a way to put a formula into cell B30 that would display the difference between all the figures i will be puting in cells B6:B29? Ive not worked with excel formulas for years so please bear with me lol
    cheers
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Ok, so you want a formula displaying the increase in weight between birth and whatver the highest value you put on the same column ? We can use this, as I guess a growing baby is unlikely to lose weight...
    1) Remove all the units ("G") from the cells, keep only numeric values, as Excel can't calculate from text ! If it's corrrect, all numbers should automatically align to the right. If they stay aligned to the left, then they're still considered as text, not numbers : check there's no quote inserted in front of them.
    2) In the B30 cell, you'll put this formula :
    =max(b6:b29)-b5
    Then of course, copy-paste the formula to the next columns.
    You may put a "$" in front of the coordinate you want to stay independant from the move when copying to other cells. For instance, if you intend to extend your spreadsheet past row # 30, you may use =max(b$6:b29)-b$5 instead, so copying the fomula to row # 40 will keep it working. Inserting rows in the middle of the table will also keep both versions working anyway, just expanding the range towards the bottom.
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    Thanks Paulwr and Z80. Appreciate the help and it got me the result i needed
    cheers
  1. MS Excel - Any Experts?
    By Aidi in forum The 'Off Topic' room
    Last Post: 22nd April 2012, 17:24
  2. excel help
    By shan in forum General Chat
    Last Post: 7th November 2007, 00:33
  3. MS Excel Experts
    By Damian in forum General Chat
    Last Post: 24th September 2006, 19:18
  4. Excel Help Please
    By jka in forum General Chat
    Last Post: 6th April 2006, 10:42
