Thread: Would I need an alignment check after replacing the top strut bearings?
    13 Post(s)
    Default Would I need an alignment check after replacing the top strut bearings?
    As per subject header.
    The offside top strut bearing is sounding rough. Due to the bad weather and lack of time I have at the moment it looks like I'll have to get the local dealer to do it. Trouble is they can't do it until Wednesday at the earliest.
    On Tuesday I'm having 2 new tyres fitted and a 4 wheel alignment carried out (because of odd rear tyre wear) elsewhere, all booked in prior to the noise of the strut bearing occuring.
    What I don't want is to have the alignment carried out Tuesday and then the main dealer screwing up the settings Wednesday.
    Does it all go back together as it came apart, or will it need an alignment check carrying out after the strut bearing has been replaced?
    Administrator plasma's Avatar
    On the Forum
    579 Post(s)
    Engine : 150
    Mileage : 74000
    there is slight movement on the top 3 torx bolts it allows it to twist and move slightly so yes it would alter it
    13 Post(s)
    Thanks Plasma.
    Damn!
    Need the tyres replacing ASAP and was going to get them to do the 4 wheel alignment at the same time.
    It looks like I'm going to have to take a chance on whether the Vx garage screw up the alignment after changing the strut bearing. Hopefully they'll do a basic check at the very least after replacing it to make sure its still ok.
    Regular Member any-mgzt's Avatar
    cheshire
    21 Post(s)
    Trim : basic
    Engine : Z19DT
    Whats the cost of the bearings?? Seen these on Fleabay, seems expensive:-
    http://www.ebay.co.uk/itm/VAUXHALL-V...#ht_545wt_1018
    Aug 2012
    Scottish Borders
    Quote Originally Posted by any-mgzt View Post
    About £25 from the stealers or about £15 from eurocarparts ect.
    13 Post(s)
    Quote Originally Posted by Lostie View Post
    About £25 from the dealers
    That's what I've been quoted.
    13 Post(s)
    Top strut bearing changed on Tuesday by my local Vx dealer.
    £66.78 (price after having 25% taken off for having a Masterfit Service card)
    Part was £23.40 and took ¾ of an hour to change.
    Part No if anyone is interested is 13270705
    It wasn't worth getting the spanners out and doing the job myelf when someone else can do it for approx £43.
    Now I've got to get the alignment and new tyres sorted out.
  1. Top strut bearings, maybe?
    By Admishere in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2013, 18:29
  2. Top Strut Bearings
    By Gazz in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2013, 18:20
  3. Strut Top Bearings..
    By macdad in forum Suspension, Wheels & Brakes
    Last Post: 14th August 2011, 12:54
  4. how to fit the strut bearings?
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 8th April 2010, 19:38
