Thread: Turbo cuts out, No power, Engine fault lights on, EGR maybe?
    Nov 2012
    Derby
    Vehicle : Vectra C Estate. 1.9 120BHP
    Default Turbo cuts out, No power, Engine fault lights on, EGR maybe?
    Hi all.
    Firstly to clarify, when i say "The front of the engine" I mean the bit closest to the grill. The back of the enginer is closest to the windscreen :P
    Back in october i had a copper type pipe replaced. It was part of the EGR system. Went into the front right (As looking at it) part of the engine. It had split, and exhaust fumes were pouring into the engine bay and into the cabin of the car. This solved that problem.
    I am 90% sure the same thing has happened again. Not wanting to spend more money fixing it again, Im going to bypass the EGR, (Read lots of stories telling me to do so)
    Over the past week i've noticed a drop in power, turbo not obviously working to its full potential. Then today it stopped working all together, with the spanner light coming on. A switch off and on again solved it, but this happened 10 times on the 20 min drive back from work today, regardless of what revs i was doing.
    Came home to find the EGR blanking plate had arrived from ebay. So i fitted this between the hose and the EGR valve- Top of the engine. This has solved the fumes problem, although now i have no power at all, and a different engine fault light on. Struggles to get over 3000rpm in 3rd.
    Had enough of it now. Has anyone any suggestions? Or live near Derby and could have a look for me?
    Sorry for the essay. Thanks in advance
    Spud
    Regular Member PCMALT's Avatar
    Jun 2011
    Peterborough
    Vehicle : Signum V6 CDTI
    Trim : Custom lol
    Engine : Y30DT
    Mileage : 24000
    sounds a bit like vacuum leak to me have you checked all be vacuum pipe's and have you got any trouble codes?
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    what engine do you have ?
    Nov 2012
    Derby
    Havent checked the pipes but will tomrrow. No fault codes. 1.9, 120BHP
  1. 2.0 DTi low power/engine momentarily cuts out
    By vtrigg in forum Engine & Drivetrain
    Last Post: 3rd June 2011, 23:09
  2. Engine cuts out
    By Lloydy in forum Engine & Drivetrain
    Last Post: 26th May 2010, 12:52
  3. engine cuts out
    By thedhj in forum Engine & Drivetrain
    Last Post: 7th February 2010, 14:07
  4. Engine cuts out
    By Chippie19 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd August 2009, 09:22
  5. wobble on the car when turbo cuts in ?????
    By deano1 in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2008, 21:44
