Results 1 to 10 of 13
Thread: Spanner Light
    Jan 2012
    suffolk
    Default Spanner Light
    Hi all
    Vectra 1.9 cdi 150 2004 spanner light on no stored codes,rev to 4000 spanner light goes out and then comes back on after 30 seconds.
    Any ideas? Shaun.
    Feb 2012
    sheffield
    Vehicle : SIGNUM 1.9 CDTI ELITE
    Trim : ALL OPTIONS ELITE
    Engine : 1.9 CDTI 150
    Mileage : 140,000
    Have you tried disconnecting the egr valve and going for a run?
    Jan 2012
    suffolk
    Quote Originally Posted by bladeage1 View Post
    Hi I have disconnected egr and went on run, spanner light on all the time. I expected the eml to come on after disconnecting the egr but it didn’t.Shaun.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    When you say no codes are stored, what are you using to read the codes? As some cheap hand-held code readers will only read certain engine codes
    Jan 2012
    suffolk
    Quote Originally Posted by tony-1977 View Post
    Hi It has been tested with cheap elm 327 and a snap on codereader both turn the spanner light of when reset is hit but the spanner comes on 3 seconds later.
    Think it is egr valve as had eml light on and got code p0400a few weeks ago, when eml on no spanner light as soon as reset and turn off eml spanner light back on. Also no eml with egr unplugged. Also tried brake and accelerator trick still no codes Shaun
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    P0400 is EGR related. Check it is plugged in securely. I fell for this once, pushed the plug on and all was fine
    Might be worth removing and cleaning the EGR, as per the How To on here.
    Jan 2012
    suffolk
    Hi Thanks for replies can you remember what lights came up with loose egr plug spanner, eml or both, Shaun
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    The spanner light came on when the plug was loose.
    If you blank the EGR but keep it plugged in, the spanner light will come on, followed by the eml light.
    Jan 2012
    suffolk
    Hi but should the eml come on if egr unplugged?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by shaun.b View Post
    Mine didn't. Just the spanner light.
    When I blanked of fthe EGR and left it plugged in, the eml light came on.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light reset emission light now on HELP!
    By johnny boy67 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 12:07
