Results 1 to 10 of 11
Thread: starting problems quick question
    Regular Member rickeys16v's Avatar
    N.Ireland ( Broughshane )
    Vehicle : 1.9 CDTI 150
    Trim : SRI
    Mileage : 46000
    Default starting problems quick question
    just a quick ? when i go to start my 05 cdti vec it chugs for about 15-20 seconds before it starts. thing is it will start perfect the rest of the day. i have done an oil change last week but not the fuel filter could that be the problem...
    Carnoustie
    Check your glow plugs
    Ronnie
    Mar 2012
    york
    Sounds like glow plugs...hopefully
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Glow plugs would be first port of call.
    then leak off pipes
    Trim : SRI
    Mileage : 46000
    Quote Originally Posted by ronnie63 View Post
    Ronnie
    lol im scared to ive heard of them snapping
    Carnoustie
    If you have a multi meter you can check them in situ
    Oct 2012
    Ashford, Middlesex
    good luck with this mate, i have the same problem and have spent a fortune changing parts to try and sort it out and it still does it. Does your car smoke on cold startup as well ????
    I have 2 thing left i want to try, 1 is a new or recon starter motor as a dodgey one can effect fuel pressure on start up and 2 is the injectors. I wont get the chance to do this for a few weeks as waiting for my little girl to be born so need the car in one piece but will let you know how it goes .
    so far i have changed
    thermosat, glow plugs, egr valve, map sensor, dmf and clutch, battery, fuel filter, airfilter, oil change and filter, waterpump and timing belt kit
    Trim : SRI
    Mileage : 46000
    im going to change the glow plugs today hopefully thats the problem as my spanner light comes on for a couple of mins then goes off
    hope you get it sorted dontsnatch cause you will soon have changed the whole car
    Oct 2012
    Ashford, Middlesex
    tell me about it lol, let us know how it goes
    Carnoustie
    Just take your time removing them! done mine they were a ***** on the 150, I used a lever type screwdriver but you need to keep them straight at the same time, I wedged a spanner behind them
    Ronnie
  1. 2.0 DTi - Starting problems.
    By Whosane in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2013, 01:22
  2. problems starting
    By jasoncow in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2011, 23:24
  3. Starting problems
    By cameron in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2011, 17:14
  4. 2.0 DTI Starting problems.
    By Davie in forum Engine & Drivetrain
    Last Post: 1st November 2008, 14:32
  5. 2.0 ltr dti starting problems
    By ashalls in forum Engine & Drivetrain
    Last Post: 10th December 2007, 22:55
