VECTRA C 04 SRI when i open a door the light dont come on! when the engine is running i have a car on the dash saying there is a door open.. Why do this work but the interior light dont?? the light come on when the switch is used tho.. any help?
Bulb blown in interior light fitting?
Bulb not connecting properly?
Fuse?
I reckon it's a case of RTFM![]()
Sounds like the door switch/sensor packed in - indicating the door is open when closed and affecting the interior light operation - won't be in the FM
I have the opposite at min... The light will come on with door open, but not with the on/off button, also the switches in the unit themselves are no longer lit...
Still never found out why but was caused when fittin the rear, but I've checked all the ribbons and there fine and so is the unit itself as I've swapped between my cars to check, so first I'd check your unit, then the ribbons, then you'll be as lost as me if its non of them...
Pay no attention to the RTFM, someone's probably used it on Woodpeck before or he's just found out what it means, whitty sarcasm doesn't translate well on forumslol
RTFM won't help haha, mine did this and was one of the door switches, a quick clean and all is well
It's probably not even listed in manual
its more than likely door switch unfortunately it comes as part of lock
Can't remember, can you switch interior light off/on/on doors open? Or maybe bulb blown surely not door switch as otherwise how would the display know one was open?
