Would these fit? If so has anyone got them or seen them on a Vec?
http://www.ebay.co.uk/itm/Vauxhall-O...item1c30f34afe
Pcd is okay, email one of the sellers to check the offset just.
the off set is 5x110 sure vectra is 5x110/111
PDC is the stud pattern ie 5x110 or 4x100. Off set or ET is the about the wheel sits into or out of the hub. For example et35 will sit towards the arch 10mm more than et45. Hope this helps![]()
