Thread: reverse sensors fiiting on estate
    Aug 2009
    mansfield
    Default reverse sensors fiiting on estate
    hi im trying to fit some after market reverse sensors to my 04 estate i have managed to fit the new lower bumper skirt. But now wanting to power it up ive looked in the haynes manual and it shows to connect to black wire on reverse light circuit. This doesnt show which wire on the rear fuse box to connect to. does anyone have a photo showing which wire to connect to and where abouts on the fuse box it is.
    thanks
    alex
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Aug 2009
    mansfield
    thanks is this plug the same on a estate as well. where abouts did you get the plug from on the fuse box
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Quote Originally Posted by ajm26 View Post
    I didn't do that post I saw it the other day and thought it would help you - that is a hatchback but I have a 2004 estate and the wiring looks the same as that - not sure which plug you are referring to - but the one in the picture is the one from the rear light cluster and you just tap into the wires indicated. Your probably best contacting the poster who I am sure will be able to help you more.
  1. Estate reverse light wire - ID for park sensors
    By isdmac in forum Electrical & ICE (including SatNav)
    Last Post: 11th July 2012, 20:01
  2. Help with reverse sensors
    By booker413 in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 22:41
  3. fiiting roof bars on the roof rails of a vec estate 2004
    By tinus71 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2010, 19:50
  4. Reverse sensors
    By silverhairedracer in forum Insignia car chat
    Last Post: 27th October 2009, 22:44
  5. fitting reverse sensors to an estate
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2009, 23:00
