Thread: fitting a double din, but......
    Feb 2007
    Norfolk
    Default fitting a double din, but......
    just had a thought.
    Car is a 2008 Elite, and I'm looking at fitting a Pioneer AVH 8400 BT unit, I'm going to get the connects 2 kit that will keep the functionality of the steering wheel controls etc.
    Now the 'silly' bit......
    Will the controls for the climate control etc still work the same on the same unit?
    APOLOGIES if this is a stupid question, but...... :-(
    Regular Member Spelly's Avatar
    Derbyshire
    6 Post(s)
    Ive got an 03 gsi with pioneer avh 8400bt and dual climate and everything works as it should using connects 2 fascia kit and wheel controls
    Feb 2007
    Norfolk
    PS. can anyone point me in the right direction of a full wiring kit for it, initial searching looks like no-one does the complete change over kit for it? (i've ordered the celsus facia from Amazon recommended in a different post)
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    For the wiring, the connects2 part number would be ctsvx002, with CTPioneerLead as the patch cable. Search for Dynamic Sounds on ebay, they generally do the two of them for about £35 delivered.
    The aerial adaptor should be CT27AA17, again - available from ebay. That should sort it out.
    newport
    is it correct you need to find an ignition live from cig lighter to power headunits in a facelift? father in law is thinking of doing the same to his
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Ish... it depends on the adaptor.
    The CTSVX002 doesn't, as it generates its own +12v turn on from the canbus. It also provides handbrake switch, reverse sense and speed pulse for navigation/AV systems. The standard non-stalk adaptors (or some older stalk controls) require a +12v switch from the cig lighter to tell the radio when to turn on.
    That's why personally I recommend the CTSVX002 adaptor, it's easy as owt to fit! As long as you remember to make the last connection the one to the car, you can't go wrong (basically plug everything into the radio, then before you slot it home, plug the two quadlock sections together).
    newport
    cheers
    Feb 2007
    Norfolk
    thanks Spelly & BoostPuppy, really appreciate the quick responses. Off to order now.
    Cheers again.
  1. Double din fitting kit
    By stevie16v in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2012, 22:06
  2. Double din fitting kit
    By rob2.0t in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2012, 20:57
  3. Double din fitting help
    By blackveccyC in forum Electrical & ICE (including SatNav)
    Last Post: 17th February 2012, 22:39
