Results 1 to 10 of 18
Thread: CDTI Battery Type/Size
    Jan 2012
    Silverstone village
    Default CDTI Battery Type/Size
    Hi With the cold weather and some dodgy glow plugs seems I require a new battery as it just wont crank for long like it used too at the start of the winter...
    Just wondering what battery type I should be looking for (Amp hours Cold crank amps etc...)
    Would this fit the bill:
    http://www.ebay.co.uk/itm/12V-80Ah-700-AMPS-EXIDE-CAR-BATTERY-HEAVY-DUTY-BATTERIES-12-VOLT-/160728267782?_trksid=p5197.m1992&_trkparms=aid%3D1 11000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D14%26m eid%3D6191771079003469316%26pid%3D100015%26prg%3D1 006%26rk%3D2%26sd%3D160924241183%26
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Why not drop a message to check?
    checked with local factors they advise 72-80Ah, circa 750 CCA
    Looks a good battery....
    Good luck!
    Jan 2012
    Silverstone village
    Thanks have sent a message , seems a good price though for a Varta battery with 4 year warrenty.
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    mon,
    that isnt a bad price for a battery, when the likes of GSF want £90 for a 'cheap one' and Halfrauds want £100 not bad at all..
    good luck!
    Jan 2012
    Silverstone village
    Going to order one will probably pick one up and fit in there car park to be sure , measured mine a standard vx one 32cm x 18cm x 17.5cm (w x d x h) so seems a good match to the one advertised, I'm.in a bit of a rush as I'm having to jump mine every cold start.
    Jan 2012
    Silverstone village
    Battery fitted a treat , ended up getting a different Varta battery from the same people, 80AH with 800 Cold cranking amps for £60 (3 Year Warranty), they even fitted it for me when I turned up.
    Battery is stickered up with Varta and a Land rover Jaguar sticker on it.
    Ebay link to battery.
    http://www.ebay.co.uk/itm/12-Volt-80...item256edcca83
    Jun 2009
    birmingham uk
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Mileage : 106000
    Being due a new battery too thanks for this post and ebay links, having looked on ebay also come across this Varta battery http://www.ebay.co.uk/itm/110-12V-80...item3f22240f5d at a reasonable price. Which to choose? Any recommendations?
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    It's actually a matter of size. I had fitted up to a 95 Ah battery in the past, but the cover couldn't close perfectly and kept the bonnet slighty lifted.
    Now some manufacturers make smaller but more powerful batteries. For instance, Varta now makes 85 Ah batteries not larger than regular 75 Ah ones.
    A higher capacity battery helps when you're using large audio amplifiers. And for diesel engine start, of course. You might also need a powerful enough alternator (just because a too small one might suffer charging a bigger battery), so of course, you'll fit larger batteries if you've got a diesel car, where the alternator is oversized already.
    Jan 2012
    Silverstone village
    Quote Originally Posted by no1vic View Post
    The one I got has 800 cold cranking amps vs 740, although the same price with postage doubt it makes Much difference the one you posted had 4 year warranty as oppose to the one I got with 3 years.
    Maybe flip a coin ? The dimensions of the one you posted should fit.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    My personal rule - get the most powerful that will physically fit. Better to have one working at 70-80% capacity than one having to work at 95+% capacity.
  1. battery type
    By buffallobill in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2012, 20:00
  2. Battery size
    By paulvectrac in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2012, 19:28
  3. Battery pic and type
    Last Post: 1st February 2011, 22:02
  4. battery type
    By taxidriver50005 in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 20:15
  5. battery size
    By daveg8843 in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2007, 12:27
https:www.vectra-c.comforumshowthread.php183348-CDTI-Battery-Type-Size
is 100 amp hour battery for vauxhall signum
vectra c battery too small
