is it much of a job? whats involved?
The dimming mirror runs off a separate loom to the interior lights/light-up visors, etc. It's as straightforward as dropping the headlining some and running the loom from front to back where it plugs into the REC. The mirror is straight slide-on replacement for the bog-standard one. Well worth doing it not to be dazzled by numpties behind you.
Sure there are some how-2's for this, either way its not that difficult.. I went a bit further and wired in the dimming drivers door mirror on my vec too, and i've added a dimming rear view mirror to the girlfriends old corsa b and her current mk4 astra.
am shore it can be done with some speaker cabsle just igniton live and ground needed i think
I've done it in my Sri cut the plug off and used some speaker wire and wired it to a 12v ignition job done oh and put black on windscreen.
wich ones live though
brown I think can't remember the neg
black live
brown earth pretty sure them
spot whats the put black on the winderscrren about lmao
oh good, thanks for that, so either fit direct to rear fuse box with correct loom, or just retrofit with igniton live? does that work the little light on it then aswell?
