10th March 2013, 18:27
#1
Vectra C Fuel smell
I seem to be posting weekly since I have owned my Vectra C Direct, It seems obvious that the Z22SE is a much better engine than the Z22YH. lol!
I can now smell fuel from inside the car and when I turn the engine off and listen I can hear like a hissing sound around this area in particular:
Is there any common problems or easy ways to find the leak without using a lighter or match
Cheers Guys
10th March 2013, 19:44
#2
i had a fuel smell turn up in the car, so while car was running had a look under the car and can see petrol dripping out from under the engine, turned out to be a dodgy fuel injector seal and was leaking from that, same sort of area as the picture aswell
10th March 2013, 20:25
#3
Thanks for that, Im hoping that the job is easy enough to do! Did you take your to a garage or do it yourself?
10th March 2013, 22:25
#4
i had a leaky injector seal on my signum once, it would stink of petrol as well. It was quite an easy job to fix but I had to change the O rings around the injectors and the cups..
Post Thanks / Like - 1 Thanks, 0 Likes
10th March 2013, 23:56
#5
Would a leaking injector still making a hissing noise after engine is turned off tho? does it for about 5-10 minutes, so im assuming its something to do with high pressure. Are the fuel lines high pressure before the injectors or before and after?
Regards
11th March 2013, 00:10
#6
no mine did not do that... once the engine was off it was quiet... doesn't your engine have the high pressure fuel pump in the engine bay?
11th March 2013, 00:24
#7
Yeh it has the dreaded High Pressure Fuel Pump, but no noise coming from that luckily!
11th March 2013, 12:21
#8
i took it to a garage, cnt say if it made a hissing noise or not i didnt have a listen was more concerened with the smell of petrol
11th March 2013, 15:35
#9
Ahhh right, Thanks anyways
11th March 2013, 22:30
#10
Have you checked out the website http://www.z22se.co.uk/forum/
These guys have loads of knowledge and info on both the Z22SE and Z22YH engine, they might be able to help.
