Thread: (Swirl bar) fair play to everyone that put it back on
    Regular Member SEANYboi's Avatar
    Dec 2012
    Bourne end,high Wycombe
    5 Post(s)
    Vehicle : Vauxhall vectra
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Default (Swirl bar) fair play to everyone that put it back on
    Replaced my glow today, also tried to put swirl bar back on , used the washer trick, but couldn't get the ****** thing back on. Lined all the swirl flaps up, tried to push it back on, but everything kept moving, then the washers started to break off, so gave up. So fair play to everyone that managed it.
    Better get saving
    Dec 2012
    5 Post(s)
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Glow plugs btw
    Aug 2012
    berkshire
    i did it to mine and it lasted ages,about 10k beofre it fell off last week due to the glue comming unstuck on the of the fixings.
    I had to make the hole slightly bigger(a fraction of a mm) to get it to pop over the ball joint bit but once its on it stayed on for a long time.
    I do need a new manfold as all my swirl pots are leaking oily gunk like crazy but for a temp fit to keep MPG high and low down torqe its a brilliant.
    Regular Member shinyb1's Avatar
    Jul 2011
    wigan
    when my bar came off i used numberplate caps and industrial super glue with activator to glue the caps on . to get the bar on - if you look in the middle of the bar there is a very small hole , i used a very thin t-bar alan key and glued it in the hole. then i lowered it in position and pressed the bar on with a screwdriver , while pressing the bar down i twisted the alan key to release it . the bar stayed on for 8 months till i had the inlet changed .
    Dec 2012
    5 Post(s)
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Quote Originally Posted by shinyb1 View Post
    How do you do it with number plate caps
    Jul 2011
    wigan
    Screw-Cover-Caps.jpg you use the cup part of the caps and glue on each socket of the bar .
    Dec 2012
    5 Post(s)
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Thanks mate. Done it now
  1. Well, fair play to Ford!
    By AndrewTi in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2008, 21:06
  2. Fair Cop
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2008, 00:24
  3. This biker is on a death trip but fair play.
    By rickyroo in forum Comedy & Humour
    Last Post: 30th June 2007, 12:53
  4. Got car back, fair bit has been done!
    By pacarcher in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2006, 15:46
  5. So not fair!!!!!!
    By MARKYBOY in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2006, 19:35
