Results 1 to 10 of 15
Thread: park pilot speaker plug location
    Regular Member squirrell25's Avatar
    Jan 2010
    wednesbury
    Vehicle : SIGNUM 2.0T
    Trim : WAS DESIGN
    Engine : Z20NET
    Mileage : 99.000
    Default park pilot speaker plug location
    hi all been looking around the the signum today gettting it ready for the factory fit park pilot
    i had part of the roof lining down to find the plug for the speaker but couldn't find it
    i know my car is pre-wired for front and rear park pilot but i just can't find the plug for the rear speaker
    has anyone got any idea where it is
    Regular Member althion's Avatar
    Apr 2012
    lancashire
    21 Post(s)
    Engine : 1.9 CDTI 150
    It is taped to the headlining with the roof loom passenger side above rear door near to the B pillar
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    smack above the rear passenger headrest!
    Jan 2010
    wednesbury
    Trim : WAS DESIGN
    Engine : Z20NET
    Mileage : 99.000
    thanks for the reply
    i have had the roof lining down on the passenger side upto the b pillar but couldn't see or feel it
    guess it's not part of my roof loom
    anyone know of a way to fit it without changing the loom?
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    240 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Are you sure you've been looking at the REAR and not the front ?
    Apr 2012
    lancashire
    21 Post(s)
    if you look on the ribbon of the roof loom where it connects to the rear fusebox there will be a three letter ID. If it is QRS or QRT you should have the connector
    Jan 2010
    wednesbury
    Trim : WAS DESIGN
    Engine : Z20NET
    Mileage : 99.000
    yes defintly looked at the back i have even removed some the white tape but it's not there
    is there more then one loom type for the signum
    my loom is BBE so i am guessing that it hasn't got the plug
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    You should be able to wire up the speaker from the rec on 2 cables. Check out this link. it tells you where the connections are
    http://danborg.org/Vectra-c/Vectra-estate-parkpilot.pdf
    Apr 2012
    lancashire
    21 Post(s)
    It should be near to the rear light connector if that is still taped to the loom
    Jan 2010
    wednesbury
    Trim : WAS DESIGN
    Engine : Z20NET
    Mileage : 99.000
    thanks for the response's will take a look tomorrow i have left it all in bits for now
  1. park pilot location plug help
    By hairy31 in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2012, 18:38
  2. Park pilot alert but I don't have Park Pilot
    By krisby in forum Vectra C / Signum Troubleshooting
    Last Post: 21st November 2011, 10:58
  3. Park pilot speaker
    By bigmac in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2010, 21:49
  4. Park Pilot Speaker fitting
    By tramman in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2009, 00:29
https:www.vectra-c.comforumshowthread.php182937-park-pilot-speaker-plug-location
Loudspeaker low voltage astra h
vectra c caravan park speakervectra c caravan parktronic speakervectra c buzzer placevectra c park buzzer locationparktronic speaker opel signumopel low voltage pas speakeropel vectra c parking speaker locationvectra c caravan park pilot circuitpark pilot Opel signumpas loudspeaker location on vectra cwhere is front vectra c park pilot loudspeakerproblem speakerphone on vectra c CIM MODULvectra c cim speaker test https:www.vectra-c.comforumshowthread.php182937-park-pilot-speaker-plug-locationpage2ir B1000 - Loudspeaker location vectra c caravanopel vectra loudspeaker park pilotvectra c park pilot loudspeaker circuit openpark pilot loudspeaker vectra c location
