Results 1 to 10 of 15
Thread: Wiring up a relay
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Default Wiring up a relay
    Hi all can anyone help me out im wanting to wire my side lights to my numberplate light so they come on when i unlock the doors so can any one tell me what points the wires go to on the relay please.
    And my sidelights are all ready wired up to come on with the ignition would this affect it and will it affect it when the lights are on and the numberplate light comes on will it not over heat or anything?
    Jul 2011
    UK
    Year : 06
    I've done it u don't need a relay just wire it straight to the number plate wiring remove boot trim ul see the wires think it's a green wire.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Quote Originally Posted by marc vectra sri View Post
    Tried that mate but cos my light come on with the ignition the wire gets really hot for some strange reason. And was told I need to hook a relay up so it doesn't over heat.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    30 is batt pos
    85 or 86 is power control and other would be negative
    87 would be on to you side lights
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Quote Originally Posted by Critch View Post
    30 is batt pos
    So
    30 bat
    85 or 86 to the number plate live
    87 to the side light live
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Don't think this is going to work it works fine doing it without having it connected to the fuse box but soon as I connect the wire from the fuse box so they come on with the ignition a get a beeeeeeeping noise from under the bonnet.
    Am I doing something wrong.
    Dec 2011
    Seaham
    You will need to earth the other side of the relay switch, so you can have power on 85 via the sidelight switch, earth on 86 or vice versa.
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Here is a drawing showing how the relay works, and what use are each pin...
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Why not just take the dash feed one, same job no relay, there's a video of mine on YouTube...
    I'd only use a relay if you wanted to power it from a stronger source then the trigger used to light it (as its not powerful enough) as the plate is your trigger and can handle LEDs a relay is over kill IMO and not needed...
    Hanging Heaton
    35 Post(s)
    Mileage : 140k
    If you don't want to use the Dash feed, or plate (need double unlock for sidelights to fire :-/) this is how I would do it if wanted to over complicate a simple matter lol...
    30- ignition live
    87- sidelights (ignition) normally closed
    87a- sidelights (fob/interior triggered) normally open
    85/87 interior light trigger - brown & brown/white
    So... Your side lights will be on with ignition once keys in etc (relay closed) when keys out and interior light fires the lights remain lit, or light when approach the car and press the fob (relay open)... Only issue may bring up it key not in ignition and you use interior light, but side lights will just come on then off with the light, but probably already on from just opening your doors
  1. Can you name that Relay?
    By Journeyman in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2016, 17:54
  2. Vectra C towbar electrics/Relay wiring
    By canny03 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd March 2012, 01:31
  3. vectra c towbar wiring 7 pin relay help needed asap
    By hixeylad in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2011, 21:23
  4. Vectra C towbar electrics/Relay wiring
    By canny03 in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2009, 11:02
  5. Which relay is which?
    By JamesG in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2007, 19:18
