Hi all
thought I would give my GID conversion a go myself.
I'm armed with a gas soldering iron, some solder & these 0603's I've got dron eBay.
They look tiny?!
where do I start? Ive read the how to but my smd's look tiny.
Hi all
They look tiny?!
Start by getting yourself a proper temeperature controlled iron , you will cause damage with a gas one.
i ordered 0603 for my oddemeter lcd screen which is same as gid smds as i was told there the ones well like u said there tiny far too small not the right ones there even smaller than the 0805 you use for steering wheel scrollers, so i just did what i did with my gid and used 3528 plcc2 smds and mounted them slightly offset over 2 pads rather than 4 if u know what i mean
Please take kman247 advice. It will end in tears otherwise.
Are you intending doing the whole car or just the screen.
I would get the iron mentioned. 20 quid off ebay for a starters kit.
If you have not tried this before i would get a spare switch of sorts and practice removing and soldering on new leds before starting on your own bits.
http://item.mobileweb.ebay.co.uk/vie...id=30034715969
excellent advice and i wish i'd followed it when i did mine!!
used a gas soldering iron first off on the rear window switches and destroyed the pads!! Then saw the light and bought a decent electric iron, the difference is amazing! also if you are doing the steering wheel be very careful hen de-soldering the old SMD's i lifted the pads on 2 of mine (one on each side) so now have no SMD's fitted in those!!
