Results 1 to 10 of 14
Thread: 150 CDTI vaccum pump?
    Feb 2012
    sheffield
    Vehicle : SIGNUM 1.9 CDTI ELITE
    Trim : ALL OPTIONS ELITE
    Engine : 1.9 CDTI 150
    Mileage : 140,000
    Default 150 CDTI vaccum pump?
    Hi,
    Can the vacuum pump fail on the 150 cdti engine and if it was not working properly would it restrict turbo boost?
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    take the small pipes off and check for oil normally the seals normally go and yes it would affect turbo
    but so will the pipes if there leaking something that's common too
    Feb 2012
    sheffield
    Mileage : 140,000
    Cheers John,
    Can I tell if I take the pump off by looking at it? there does seem to be pressure through the pipes and I cant see any oil, is the pump gasketed?
    cheers
    Jun 2012
    lancashire
    if theres no oil in the lines then you should be fine more likely the vac line has a leak somwhere
    have you been able to read the boost pressure? theres alot of phone apps now that will do it see what its producing
    Feb 2012
    sheffield
    Mileage : 140,000
    yes I have read the boost pressure as follows....
    1500 rpm it is at 2.3 psi
    2000 rpm it is at 4.7 psi
    Jun 2012
    lancashire
    it needs to be checked whilst under various loads you need to see if its boosting up to its max ect then you will know if its faulty
    Feb 2012
    sheffield
    Mileage : 140,000
    ....any ideas where I can get the standard boost values from so I can check them against mine?
    cheers m8.
    Jun 2012
    lancashire
    under load your turbo will boost more the greater the load the more it will boost
    whats actually happening whilst u drive to make you think theres an issue?
    Feb 2012
    sheffield
    Mileage : 140,000
    I start it and drive away, there is a very very short noticeable boost from first and second gear, I change into third gear and the boost is still there but not as strong, change into the higher gears and it is boosting but very weakly....just enough to be noticeable but not like it used to.
    I have totally cleaned all the induction side of things,sensors,boost pipes,manifold,turbo etc etc and the performance has improved so I now do have boost in the higher gears but absolutely not like it used to be.
    I had the DPF removed 15,000 miles ago and it had a new type inlet manifold fitted at 90k (now 136k).I have blanked the egr, throttle body is all clean and working.Boost sensor (on inlet manifold is spick and span)
    It feels like it wants to go and if you lean the throttle off it picks up quicker but other than that the only time it feels 100% is when it is cold,as soon as engine temp gets up it starts to lag again?
    Feb 2012
    sheffield
    Mileage : 140,000
    question.......
    if the solenoid side (pin side) of the EGR valve was knackered would this restrict the turbo, I have unplugged the EGR and it still drives the same and there are also no codes thrown up.
    I have driven the car for 40 miles today and it seems the same, when setting off from junctions etc it pulls like a train then tails off as you go up the box, I plugged the OBD in when I got home and no codes are showing/logged....?????
  1. vaccum hose size
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2012, 13:33
  2. Boost/Vaccum pipes
    By garetmcc79 in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2012, 12:25
  3. Vaccum gauge
    By paulvectrac in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2011, 22:09
  4. vectra vaccum box
    By sclarkson82 in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 17:19
  5. vaccum problems 3.2 V6 Ecotec
    By CDUB in forum Engine & Drivetrain
    Last Post: 11th August 2009, 19:53
