Thread: Brake warning light (o)
    Apr 2011
    hereford
    Trim : Elite 2.2 DTI
    Year : 2053
    Mileage : 108122
    Default Brake warning light (o)
    Hi i have a brake pad warning light showing on my dash and was wondering if there is anything else that could cause this illumination. I have recently changed front discs and pads and also bridged the wires together but the light still stays on does any one have any suggestions please many thanks
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    have you bridged the correct wires? someone did cut the abs wire by mistake as the brake pad wire was missing.
    Chelmsford
    I had a pad warning a while back because the sensor had slipped from it's mounting and got mangled by the disc itself.
    Apr 2011
    hereford
    Year : 2053
    Mileage : 108122
    LoL i did see that post but no its the correct wire or wires rather it came on before i changed the discs and pad and still remains on
    Apr 2011
    hereford
    Year : 2053
    Mileage : 108122
    Anyone
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I believe that warning icon also displays for low brake fluid level.
    Apr 2011
    hereford
    Year : 2053
    Mileage : 108122
    The fluid level is full
    Apr 2011
    hereford
    Year : 2053
    Mileage : 108122
    Anyone ?
    Apr 2011
    hereford
    Year : 2053
    Mileage : 108122
    burrrrrrrr no one
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Looks like you'll just have to eliminate points one by one ... if you can find the ECU end of the sensor wire you can then confirm continuity - obviously you are looking for a continuous loop from ECU to pad sensor and back as the sensor being worn away and thus breaking the circuit is what makes it work...
    ... once you've got past that stage it's then reassess and formulate a new plan.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake Pad Warning Light
    By PedroMV6 in forum Handling & Braking
    Last Post: 10th May 2011, 21:11
  3. Brake Pad warning light
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2010, 23:38
  4. Brake pad warning light comes on...
    By m8internet in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2009, 20:42
  5. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
