Thread: Key
    Sep 2009
    Glasgow
    Default Key
    Hi all, problem tonight , key fob has been loosing range last few days, having to go closer and closer to unlock car, replaced battery but still the same, lock button has started to stick, took apart fob, sprayed with electrical contact cleaner, put back together, lock button has stuck on, and car wont start at all with key, I get the spanner light flashing and nothing happens , only have one key now, that worries me, spare works fine and from distance, whats my options without paying £150 at the stealers, have the software and hardware that's not allowed to be spoken about, but is this dangerous. Need another key.
    Sep 2009
    Glasgow
    http://www.ebay.co.uk/itm/VAUXHALL-4...item4d09b54a39 would this kind of thing be ok I could just swap out blade and reprogram key
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    That says used you cant reprogram a key thats all ready been programmed it has to be a blank key. you do get sellers on ebay selling new keys for £100 and they will program and cut the key for you're car if you sent them you're code.
    Sep 2009
    Glasgow
    cheers bud
    Sep 2009
    Glasgow
    im a member of service club includes parts, key is a part would it be likely I would get 25% off key.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Np im the same i only got one key and need a spare i was going to get one from the stealers but someone on here posted up a link to ebay with someone selling new ones programmed and cut but i cant remember who the seller is but new new coil overs and a few other things so key is on hold lol
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    240 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    I'm not sure about your key choice, it doesn't look like it's a key from a Vectra / Signum to me, but I'm not an auto locksmith.
    I would recommend you contact a seller such as the one below to make sure you get a brand new keyfob that WILL program to your car.
    I have not used this seller myself, but he gives every impression of knowing what he is talking about and at around £50 it seems about right IMO.
    This seller is advertising brand new keys which simply need programming using kit like the one you have already, you should be able to swap your keyblade over without difficulty.
    http://stores.ebay.co.uk/car-key-ser...4.l1581&_pgn=2
    Sep 2009
    Glasgow
    just used that key as an example, cheers for the site, was looking at this it looks promising. http://www.gallalock.com/46-vauxhall...er-replacement
    Sep 2009
    Glasgow
    is it possible to just get a immobiliser key that will open doors and start car.
