Thread: fog light problems
    Regular Member dahmich's Avatar
    cwmbran
    Default fog light problems
    anyone had problems with their fogs? just had the warning come up with the left fog but it still ok, ironically its the fog which has condensation in it and i pulled out all connections, wd40 them, dried them etc, put it all back and still coming up with the error. error code comes up circuit open? but like i said...fog still works...any ideas??
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    I had a similar problem i had fog light warning pop up and mine worked but then after a while they worked intermittently, i got under neath and wiggled the wires and the bulbs would flicker on and off which made me think i had a problem with my wiring which i was going to buy brand new connectors, my fix was a trip to halfords bought new bulbs has i broke one lol and that cured the problem it seemed that the bulbs were at fault as they were on there last legs.
    cwmbran
    pip, do your dash warning go out if you put the bulbs on, then when you turned the fogs off the warning would come back?
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    My dash warning light would not go out it finally did once I changed the bulbs even though they still worked I found this quite strange
    13 Post(s)
    Bulb resistance can change prior to it finally giving up the ghost. Sometimes it's enough to trigger the bulb failure warning.
  1. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  2. Problems with Side Light SMD /Led
    By Envy in forum Styling
    Last Post: 17th April 2011, 20:48
  3. Side light problems
    By VX Dan in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2009, 16:50
  4. Cat Light Lit! Starting problems too!
    By hibbsy18 in forum Engine & Drivetrain
    Last Post: 27th January 2009, 17:00
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
