Thread: "Proper" overhaul of engine...
    Chelmsford
    Default "Proper" overhaul of engine...
    Hi chaps,
    Maybe I'm being a bit insane here, but I fancied getting my hands dirty so was thinking of planning a full overhaul of my engine.
    It's done 104k and has always been fully serviced, no expense spared. Naturally, given the age and mileage, it doesn't run as smoothly or quietly as it used to. Nothing actually wrong with it, I just enjoy trying to achieve perfection!
    What sort of work would I be looking at to get my pokey 1800cc back to it's best?
    Any obvious parts which wear and don't get replaced under the general service schedule?
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Quote Originally Posted by DNS View Post
    Hi chaps,
    Maybe I'm being a bit insane here.....
    Yup!
    An engine that has done over 100k obviously isn't going to be quite as good as the day it left the factory. As long as it has been properly serviced, and you continue to do so, then I'd say that old saying of "if it ain't broke" applies.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    if its getting noisy try thicker oil 5w40. a proper overhaul you mean stripping the engine and replace bearings and cam shafts?
    Chelmsford
    Quote Originally Posted by puppet View Post
    Yup!
    Thanks for confirming! I was always sure it was the case!
    Was basically thinking that of replacing bearings and piston rings as I'd assume they've taken a fair bit of wear over the years.
    Going to get the cambelt and clutch done soon anyway, so it seemed like a good opportunity to do a few little extras!
    South east
    Do a compression test, that will tell you if there's an issue within the combustion chambers.
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. "Proper" car ramp/lift
    Last Post: 13th March 2012, 00:15
  3. engine management light "limp" mode
    By welshoneder in forum Engine & Drivetrain
    Last Post: 28th October 2010, 10:31
  4. Replies: 0
    Last Post: 9th June 2010, 09:19
  5. Thinking of getting a "proper" jack
    By PeterVV in forum General Chat
    Last Post: 5th December 2009, 23:02
