Notes
Items pictured but not listed are not installed on your vehicle.
Items pictured without a number are listed on another diagram. |
N° |
N° de pièce |
GM |
Name |
Quantité |
17. OIL PAN AND FITTINGS |
1 |
12576654 |
652056 |
PAN,ASSY.,OIL (NLS.- USE 55557091 56 52 007) |
1 |
1 |
55557091 |
5652007 |
PAN,ASSY.,OIL |
1 |
2 |
11519933 |
652736 |
-PLUG,OIL DRAIN |
1 |
3 |
3536966 |
652526 |
-'O'RING,18 X 2,DRAIN PLUG |
1 |
4 |
24461500 |
6238220 |
SENSOR,MINIMUM OIL LEVEL,OIL PAN |
1 |
5 |
11095001 |
2018065 |
-SCREW,TORX,M6 X 20,TIMING CHAIN SLIDE RAIL TO CYLINDER HEAD |
2 |
6 |
11094181 |
2080745 |
-CLIP,OIL LEVEL SENSOR HARNESS (NLS.- USE 55565455 20 80 036) |
1 |
7 |
11052823 |
2060661 |
PLUG,EXPANSION,22 MM OD.,WATER JACKET |
1 |
8 |
11518049 |
2000078 |
SCREW,M8 X 25,OIL PAN TO CYLINDER BLOCK |
0 |
9 |
11518058 |
2000080 |
SCREW,M8 X 100,OIL PAN TO CYLINDER BLOCK |
1 |
10 |
11518056 |
2005049 |
SCREW,TORX,M8 X 75,CRANKSHAFT BEARING COVER TO CYLINDER BLOCK |
10 |
11 |
22531637 |
2086017 |
PIN,OIL PUMP |
2 |
12 |
90542117 |
1510181 |
COMPOUND,LOCKING,50ML,AIR BAG SCREW |
0 |
13 |
90543772 |
1503298 |
COMPOUND,SEALING,50 ML,CAMSHAFT COVER (NLS.- USE 93165267 15 03 305) |
0 |
18. OIL LEVEL INDICATOR |
14 |
55351960 |
658083 |
ROD,OIL LEVEL INDICATOR |
1 |
14 |
55354741 |
658220 |
1 |
15 |
90529866 |
658131 |
-'O'RING,OIL LEVEL INDICATOR ROD |
2 |
16 |
55350429 |
5658312 |
GUIDE,OIL LEVEL INDICATOR ROD |
1 |
16 |
55354740 |
5658335 |
1 |
17 |
90467275 |
658431 |
-'O'RING,GUIDE,OIL LEVEL INDICATOR ROD |
2 |
18 |
11518060 |
2000081 |
SCREW,HEX.HD.,M6 X 10,OIL LEVEL INDICATOR GUIDE TUBE TO CYLINDER BLOCK |
1 |
19. OIL LEVEL SENSOR |
4 |
24461500 |
6238220 |
1 |
