Thread: Z20NET. dump valve?
    Regular Member JM53 BEL's Avatar
    Oct 2012
    Clackmannan, Scotland
    Trim : Elgance
    Engine : 2.0 Turbo
    Mileage : 106000
    Default Z20NET. dump valve?
    Got myself an atmospheric dump valve as really dont see point in a recirc, yes i knoq there quiet an less chavtastic but i like the sound from a dumpvalve. I got it after replacing my turbo which cost me a small fortune! To help relieve pressure build up when i do use Turbo.
    Can i just fit the dump valve or will it interfere with anything?
    Also next on my list is the dreaded timing chain as i get a rattly sound on stat up from cold, then when heat builds up goes away, first thought ac pump. Who has done theres an is there anything i should watch out for?
    Grantham, Lincolnshire
    63 Post(s)
    Trim : SRi (Rather Modified)
    Engine : 2.0T Maptun (240bhp)
    The whole "point" of the recirc is to keep the turbo spooled up so that it's available immediately when you press the loud pedal. Dump all that pressure to atmosphere and you have to wait for the turbo to spool up again when you put your foot down hence massive turbo lag.
    Your call of course, but if the choice is instant available power when it's needed or a noise sounding like a horse has farted in the engine bay, I know which I'd prefer
    Jul 2011
    UK
    Year : 06
    what Ian said used to have a dump valve on my old astra turbo was fitted when I bought it I did like it however as soon as it dumped the turbo took longer to spool up
    Oct 2012
    Trim : Elgance
    Engine : 2.0 Turbo
    Mileage : 106000
    I had a re circ on the skyline then put an atmospheric on it and thought the atmospheric felt better, but i dont really hammer or race i am just looking to put less strain on turbo hence i was thinkin atmospheric. I know recirc is to help keep boost up for quicker response but can also build up pressure
    Regular Member garyvectrac's Avatar
    Sep 2012
    luton
    Vehicle : vectra sri dti
    Trim : design
    Engine : 2.2dti
    Mileage : 70,000
    on my old signum turbo, i simply put a performance cone filter on mine, you then have the standard system but you can hear recirc valve. best of both worlds, also get a bit of induction raw. miss my old siggy T.
  1. Z20NET and a dump-valve
    By hog in forum Engine & Drivetrain
    Last Post: 16th June 2012, 17:34
  2. Dump valve fitting z20net
    By tomo41 in forum Engine & Drivetrain
    Last Post: 14th July 2011, 13:14
  3. dump valve z20net remapped engine
    By tomo41 in forum Petrol Engine related
    Last Post: 6th June 2011, 22:26
  4. Dump valve fitting help on z20net
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2010, 21:47
  5. Z20net dump valve Help!!!!
    By dansis in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2010, 14:23
z20net dump valve
https:www.vectra-c.comforumshowthread.php182325-Z20NET-dump-valve
vectra 2.0 turbo dump valve
atmospheric dump valve z20netz20net dump valve installationz20net oil presure relief valve removavectra c z20net turbo lagfitting z20net dump valve diagram
